car wont crank!!!
Old Mar 7, 2012 | 09:29 PM
si-lude4evr's Avatar
Default car wont crank!!!
ok so i have a 94 civic cx with a b18b1, first, only once and awhile the car would not turn over it would repeatively click and sometimes only click once and sometimes it would start no hesitation, eventually it wouldnt start at all, tested the starter today and it was junk, went and bought a new one today put it in wouldnt even crank over, clicks once and thats it, speed jumps up check engine light goes off untill you let go of the key, pushed the car back a little and slipped the clutch to turn the motor over a little and turned the car and started right up, drove it home now it doesnt start, tryed the same thing by turning the motor over didnt work had to bump start it, i was thinking maybe the flywheel is worn down??? replaced the grounds last year maybe a little longer im going to replace those tomorrow, could it be the distributor?? im not to good with wiring but ive heard some people say it could be the main relay?
Anyone had this happen? anything i should specifically check, any help would be great
Old Mar 7, 2012 | 09:33 PM
Dc4LsTeG's Avatar
EK9
Default Re: car wont crank!!!
As you said check your grounds and main relay. Have you checked your battery?
Old Mar 7, 2012 | 09:35 PM
12.6 with key off
and its from last year
Old Mar 7, 2012 | 09:37 PM
and im not to familiar with the wiring thats in my car, i didnt do the swap, any idea where the relay would be? or what i should be looking for, and ya ill let you know what happens when i replace the grounds
mynameizstitch
Mar 17, 2012 10:55 AM
Tad
Jan 3, 2006 06:37 PM
del_parker
Oct 25, 2003 08:06 AM
patastinky
Sep 4, 2002 06:51 PM
hmonglonertim
Apr 26, 2002 02:12 PM
