Help: del sol/D16y8 swap - won't rev past 4k rpm after replacing distributor
Old Mar 6, 2012 | 08:03 PM
509delsol's Avatar
Default Help: del sol/D16y8 swap - won't rev past 4k rpm after replacing distributor
So I bought a 95 del sol and when I had got it it was driving fine pulled strong
Drove it home. 2 hours later died on the freeway and didn't wanna turn on.
The guy had done obd2 to obd1 wiring for the motor ?
I changed the dizzy and bought a z6 dizzy and the check engine light was on but it had been on since I got it. But when I drove it this time the rpms would not let me go past 4k . On my way back home the car died and did not turn back on. Idk what could be wrong with it . Any ideas?
Old Mar 6, 2012 | 10:18 PM
509delsol's Avatar
Default Re: Help: D16y8 in del sol
Bump for help
Old Mar 6, 2012 | 10:40 PM
Dc4LsTeG's Avatar
EK9
Your in limp mode. What cels are you throwing?
Old Mar 7, 2012 | 12:06 AM
jbpnoman's Avatar
Seriously, pull the CELs.
Old Mar 18, 2012 | 08:21 PM
509delsol's Avatar
I got the Intake temp Sensor #10 as well as #19 witch is a/t luck up silanoid ? I wired up the temp sponsor and it went away then came back up . How do I fix #19?
Old Mar 19, 2012 | 01:30 AM
HondaPartsHero's Avatar
Technical Hero
Is it an automatic? If not you have an automatic ECU and can't get rid of that code unless you convert the ECU to manual.
Old Mar 22, 2012 | 07:45 PM
509delsol's Avatar
Default Re: Help: del sol/D16y8 swap - won't rev past 4k rpm after replacing distributor
Yea I was trying a different ecu but now the car doesn't even turn on . There is a lot of wires that are cut under the dash and there is a replay they wired to the fuel pump and i wired it to power and the fuel pump primed but wouldn't turn on -_-
tuvtec
Aug 30, 2014 10:24 PM
Noodle$
Apr 19, 2011 10:17 AM
nvmisi
Sep 27, 2010 05:51 PM
