99 ex D16Y8 not shifting
Old Mar 6, 2012 | 04:55 PM
klee_miles's Avatar
Icon2 99 ex D16Y8 not shifting
Tech. Info :
1999 civic ex vtech sohc (D16Y8) 179,000 mls.
History :
motor work/ replaced 2012 old one failed due to lack of oil maintenance Installed knock sensor engine did not have one installed. Done by private person. Second-hand motor purchased junk yard.
After work on engine A/T will not shift,no forward in D4, clunk when shifting from P,take off in second. RPM must hit 4000 before no clunk P2-P3
Check engine light on, Jumper test flashes 1 long and 6 short then pause. Without jumper key on light blinks once then remains on. Shift lever hard to engage, adjusted and cleaned , works. Light still out in D4 all others okay. Sometimes surging at start and accelerator sticking.HELP!!!anyone
Old Mar 7, 2012 | 01:57 AM
lthao61's Avatar
Default Re: 99 ex D16Y8 not shifting
Check to make sure torque converter bolts and tranny bolts are tight and secure
Old Mar 8, 2012 | 10:03 AM
klee_miles's Avatar
got tranny check shop says linear soloniod pulled code 1768 says trannys ok for now. think it's possible to replace myself?
Old Mar 8, 2012 | 11:11 AM
94EG8's Avatar
Seagull Management
It's easy enough to replace, it just bolts to the front of the tranny. Unless it got damaged during the engine installation I somehow doubt this is the cause of your problems.
Old Mar 8, 2012 | 11:23 AM
Texas4door's Avatar
I'd be kicking in the door of this "private person" demanding an explanation as to why they thought the condition it's in was ok when they finished the job!
D<
5.4ever
Jul 17, 2014 08:23 PM
seanewing
Apr 29, 2010 12:18 PM
honda_S
18
Apr 6, 2005 11:00 PM
.Kevin.
Feb 13, 2005 06:55 PM
scrapin777
Jul 29, 2002 01:39 PM
