99 ex auto tranny goes into neutral sfter 1st shift
99 ex coupe 190k miles.
Yesterday I was leaving a restaurant when the tranny just went into neutral mode. Dash still sayd its in gear but it doesnt move forward just stays in neutral
I turn it off, and it goes into gear again, then when it shifts it goes into neutral again...
did my tranny take a dump on me?
If so what should I expect to pay for a rebuild???
Re: 99 ex auto tranny goes into neutral sfter 1st shift
Sure sounds like it. I think you can scan the car to tell you if there's a transmission problem. It doesn't necessarily turn the check engine light on, since its the trans not the engine.
expect to probably pay as much as the car is worth lol
what do i need to know when buying a used trans..
my car is an EX, does the tranny have to be from an EX also???
anyone in houston know a cheap mechanic that can do the swap
Fish Twig
Why would he need to scan the car when he can scan for codes on the ecu itself using the obd scan port? Yes you can get a cel light for trans codes.
Some cheap scanners dont pick up trans codes. Mine didnt see the codes my Kia nor accord were throwing but my buddy's snap on unit did.
Sounds like its more shot out than my accord.
yes you need an EX d16y8 transmission.
no, I'm not from Texas.
I have explained this more times than I can count, just chill bro. I am unaware of sensors that can be replaced, try looking into that it really helped my accord.
do a 3qt drain and fill with either Honda auto fluid or a high quality kind. it might breath life back into the trans.
zacheryleatherw
Transmission & Drivetrain
11
08-09-2011 05:41 AM
6KAOS6
05-04-2011 11:38 PM
pjr710
08-01-2006 05:04 PM
