compression testing
Old Mar 6, 2012 | 11:58 AM
92hondaaccord8108's Avatar
Default compression testing
I recently did a compression testing on my 93 civic coupe dx and these are the numbers I got....starting from the left going right...140,155,145,145....was wondering if these numbers are good or bad?....if they are bad what should I do to make them good?
Old Mar 6, 2012 | 12:00 PM
grumblemarc's Avatar
The Grumpiest
Default Re: compression testing
Some might say that they are fine but the discrepancy between the first two numbers would worry me.
Old Mar 6, 2012 | 12:19 PM
Ok..what do u think I should do?
Old Mar 6, 2012 | 12:24 PM
The Grumpiest
Why are you even doing a compression test?
You might want to give the backstory to your question.
Old Mar 6, 2012 | 12:31 PM
sde780's Avatar
Looks good to me. There is less than 10% variance between them, I wouldn't be worried at all
Old Mar 6, 2012 | 12:36 PM
Bc I am burning oil..I got alittle blue smoke coming out of it...everytime i hit the gas but it does it every somewhat often
Old Mar 6, 2012 | 12:39 PM
The Grumpiest
Probably your rings then. A leakdown test will tell you exactly where you're having difficulty.
Old Mar 6, 2012 | 12:41 PM
How do u do a leak down test?
Old Mar 6, 2012 | 12:45 PM
JuggerNaut-CTR's Avatar
Search...look it up...
More than likely your valve stem seal
Old Mar 6, 2012 | 12:57 PM
purgat0ry's Avatar
This makes no sense...
You hit the gas and blue smoke comes out, not every time but occasionally?
Old Mar 6, 2012 | 01:00 PM
The Grumpiest
Maybe he's not looking every time.
Old Mar 6, 2012 | 01:12 PM
Yeah
SilkyJohnson
13
Feb 15, 2011 05:54 PM
humboldt_skim
May 31, 2008 08:18 AM
climb_on
Jul 29, 2007 03:40 PM
Got_soy
28
Aug 8, 2005 12:49 PM
EF8_SiR
Jul 20, 2003 10:24 PM
