H22a4 TDC Sensor Issues
Old Mar 6, 2012 | 09:32 AM
BradMartin's Avatar
Default H22a4 TDC Sensor Issues
I have an H2B swapped crx, and recently it threw CEL 8 for the TDC sensor. Found a mess of butt connectors in place of the plugs that attach the sensor wires to the harness. I went ahead and re-connected them a few times. Every time I connect them the car will run great for about 5 minutes than proceed to break up if I give more than 1/4 throttle. Only now the check engine light is gone.. if anyone can offer up some good advice it would be much appreciated. Thanks.
Old Mar 7, 2012 | 10:13 AM
97ludedude's Avatar
Default Re: H22a4 TDC Sensor Issues
i would solder the connections. if it still has this problem try a different dizzy. possibly a bad ignition control module if it does it once it heats up.
Steven Cortez
Nov 14, 2016 09:49 PM
_stephan_
Oct 20, 2014 08:22 AM
ArmedFelon99
Oct 17, 2009 03:36 PM
99d-series
May 1, 2009 08:56 AM
