95 Civic/d16a6 swap -- hunting idle after head gasket replaced
Old Mar 6, 2012 | 12:26 AM
bmg_customz's Avatar
Default 95 Civic/d16a6 swap -- hunting idle after head gasket replaced
hey guys, I just did the head gasket in my 95 civic with a d16a6 motor in it. timing looks spot on and everything else seems to look good, but it will not hold a steady idle. it surges up and down, and surges really fast if i put it in gear. if i just barely touch the gas, it revs pretty high. any ideas??
P.S. Would a bad intake manifold gasket cause this??
thanks,
Bill
Old Mar 6, 2012 | 12:47 AM
jbpnoman's Avatar
Default Re: d16a6 wont idle right
A bad IM gasket could cause a vacuum leak, which could cause your surging problems. Any CELs?
Old Mar 6, 2012 | 03:24 AM
no CEL....yet :/
Old Mar 6, 2012 | 04:35 AM
Former User's Avatar
What ECU? OBD1 or OBD0?
Old Mar 6, 2012 | 04:41 AM
jbpnoman's Avatar
Default Re: 95 Civic/d16a6 swap -- hunting idle after head gasket replaced
eh, a vacuum leak is easy to fix, they can just be hard to find. The best way I've found is to take a bottle filled with lightly soaped water and spray it wherever there might be a leak. It'll make the leak visible.
Old Mar 6, 2012 | 08:00 AM
motegicivic's Avatar
Or use brake cleaner, but do not over due it, spray around the area and if you hear a change in sound that is your problem, sometimes it will stall out.
Old Mar 6, 2012 | 08:03 AM
How could soapy water help to pinpoint a vacuum leak?
Old Mar 6, 2012 | 09:56 AM
OBD0. I'm really leaning towards the intake manifold gasket. I'll post later after I try a new one out.
Old Mar 12, 2012 | 04:53 PM
Sorry, I forgot to get back to this...it was the intake manifold gasket causing the surge. all better now.
Thanks for your help and ideas!!
thekid2390
Jul 21, 2013 12:50 AM
raider1qaz
Feb 1, 2013 12:44 PM
ULTRA911
Mar 4, 2003 10:00 AM
hybridb18
Dec 28, 2002 04:30 PM
GruvyTune
Jul 30, 2001 12:44 PM
