Flex seal rubberized stop leak in a can!
link: http://www.youtube.com/watch?feature...&v=0wHGYzHygzY
has anyone tried this on their weather stripping? i was thinking about buying this and spraying it on my 15-17yr old targa top seal. or is it a bad idea? lmk
ill see since they have a "as seen on tv" store couple miles away from home. i got a mad leak on both sides of the targa top towards the top middle of the window and also leaking from the trim on the a pillars. since its only 15bucks ill give it a shot today.
If you want to "recondition" the seal, use silicone or 'dielectric' grease.
http://www.ebay.com/itm/Genuine-Hond...item5d2fdea1d2
Or the same thing in a bigger package:
http://cgi.ebay.com/ws/eBayISAPI.dll...id=p3286.m1934
If your seal is already trashed, spray away, but test it on a neighbor's car first.
This is one of those times when I think you should just replace. Old rubber no matter what you do to it is a band aid at best.
Wasting money on products to just pay for the part later on.
If you want to give me 600 + dollars to buy just two new seals (+ 2 more for the targa and then some clips) then paypal me some money. this is a temp repair until i get new ones. How is this ghetto rig?
This stuff replaced the entire gasket on old sunroof, and looks great when it's dry. My buddy claims he patched a tire with it (Not sure until I try it myself, but based on the quality I wouldn't doubt it. I'll be going over my whole car with it this summer before a full body line-x. paid $13/can at dollar general, well worth it. It responds to sanding very well once dry too. and waterproof tight seal.
Count on a permanent fix though, as it doesn't wash off easily.
I was thinking about doing that too. I carry tools in my trunk and they're all starting to rust. Wouldn't be a permanent fix just something to stop it until I could afford a proper fix. Lemme know how it works out for you.
Any update?
Just purchased this and was planning on going this route.
Already bought the Flex Seal and thought about using a food coloring with water to see where the water leaks.
BuBBa y0!
May 11, 2005 12:42 PM
