Stripped valve cover bolts -- any easy fix?
Old Mar 3, 2012 | 05:27 PM
Joshgb's Avatar
Default Stripped valve cover bolts -- any easy fix?
I have a head where the 2 front valve cover bolts won't tighten. They are stripped on the head side. And if I do tap it where do I get new bolt to fit the new holes in the head.
Old Mar 3, 2012 | 06:27 PM
honda2uner0521's Avatar
Default Re: Stripped valve cover bolts -- any easy fix?
Have you tried to see if the threads are just messed up? Can you run a tap down through it and maybe clean the threads up? If you have to tap them out just take the tap you used down to your local hardware store and match it up with the new bolts.
Old Mar 3, 2012 | 09:21 PM
Texas4door's Avatar
Same thing happened to me
Use an easy out to pull out the old snapped off bolts, then if the threads in the head are still good, use them
If not, go find a heli-coil kit that'll fit the bolts and use that.
As for new bolts, they can be found online, at parts stores, at the dealer, and maybe the junkyard
Take your pick but make sure to get new grommets for the bolts or else you'll leak oil from under the bolt heads
Old Mar 4, 2012 | 06:17 PM
DelsolVted's Avatar
i retaped mine and used hellicoil m6x1.0 had extra bolts with new seals. honda has new bolt but will need new bushing too for about 5 bucks for bolt and seal.
Old Mar 26, 2018 | 01:32 PM
lucyismycar's Avatar
Thank you for that dimension.
When you tapped, how did you deal with shavings going into the hole that is being tapped? Is that even an issue, or is that hole closed at the bottom where shavings in said hole would not enter the engine? I'm also worried about the little tab from the helicoil.
Last edited by lucyismycar; Mar 26, 2018 at 01:34 PM. Reason: forgot helicoil portion.
4dr_Noob
17
Oct 18, 2011 08:00 AM
PatrickGSR94
Nov 15, 2008 05:40 PM
DJslepton
11
May 31, 2006 05:43 PM
lv6l
Nov 24, 2004 07:30 AM
yeegsr
Sep 23, 2004 03:32 PM
