Very interesting 99 sedan problem - intermittent starting problem
Old Mar 3, 2012 | 05:32 PM
Tree18is's Avatar
Default Very interesting 99 sedan problem - intermittent starting problem
99 sedan, auto 1.6 sohc *girl friends car*
So the car has an intermittent starting problem and has even lost all power and had to be pulled over on the freeway.
Issues: NO cel light. Sometimes when you key on the car the CEL lights up. This is when the car will not start. Other times when you Key on the car the CEL will not light up and the car will start.
I thought it was spark but since I could never get the car to do it with me driving it I replaced the Distributor to make sure that spark was happening. Im reading on here to check the Thermostat housing ground wire and go from there.
Also From reading Alldata Im also thinking I might have some luck with replacing the fuel pump relay. I hate to throw parts at it like a dumbass. but at 90hr rate at the honda shop I would like to try a couple cheap things first.
Thanks alot guys.
Old Mar 3, 2012 | 05:39 PM
Former User's Avatar
Default Re: Very interesting 99 sedan problem
Intermittent problems are tricky. Is this a no-crank or a cranks-but-won't-start problem? If the latter, then listen for whether the fuel pump primes and whether there is spark at the plugs when the engine won't start.
Old Mar 4, 2012 | 12:39 AM
Tree18is's Avatar
Default Re: Very interesting 99 sedan problem - intermittent starting problem
crank and no start, no fuel pump prime
Old Mar 4, 2012 | 03:35 AM
gsrturbo-ek's Avatar
clean your battery posts and cable make sure they are tight also check clean/replace grounds......my car had a similar problem with it loosing power and it turned out to be to my battery terminals were corroded
Old Mar 4, 2012 | 06:36 AM
Crx150zc's Avatar
Go to your local Honda dealership and buy a new main relay 60-70.00 remove glove box and it will be on the right hand side bolted to the dash. Problem solved. Hondas are known for this problem.
Old Mar 5, 2012 | 05:38 AM
Tree18is's Avatar
Thanks. thats the plan and from what I read the common issue like you stated.
Old Mar 5, 2012 | 06:52 AM
6th generation Civic main relays are not highly prone to problems like the 4th and 5th generations were. You might want to try swapping in a known good ECU.
Old Mar 12, 2012 | 06:04 AM
Tree18is's Avatar
replaced the relay for 27 dollars from rock auto and so far so good. Hearing the relay click and fuel pump prime is a good feeling, Im really sure it was the relay now.
makin1meand
Dec 10, 2008 05:00 PM
redturbosi
Oct 11, 2005 06:04 PM
Hondaboy816
May 14, 2005 07:36 PM
integsr99
Oct 7, 2004 11:01 PM
SoCal ITR
May 6, 2004 10:27 PM
