Running ok, then restart warm runs rough
Old Mar 3, 2012 | 04:40 PM
motegicivic's Avatar
Default Running ok, then restart warm runs rough
96 Civic EX Auto
I will run the car say 15 mins, go into a store say 10 mins come out and it idles rough for about 10 mins or so, sort of shakes and I can hear the tail pipe shaking. The idle seems to be steady just rough, like a shake.
No CELS
Recent plugs, wires, cap and rotor a little older.
Old Mar 3, 2012 | 04:45 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Running ok, then restart warm runs rough
Do you have a cluster with a tach?
Old Mar 3, 2012 | 05:08 PM
Yep all EX's do, the idles seems to be right around the 700 point within spec, no fluctuation like signs of a bad or dirty IACV, only happens after running and then restarted.
Old Mar 3, 2012 | 05:11 PM
The Grumpiest
I don't see a problem.
Old Apr 12, 2012 | 03:30 PM
Still having this problem, basically shut it off and is chugs when restarted, possible fuel pressure regulator?
Old Apr 12, 2012 | 03:39 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Sounds most like symptoms of a bad TW (also known as coolant temperature sensor) - usually if it is bad enough to affect running it should throw a code.
It's the two wire sensor located right under the distributor - they're easy enough to replace, and if you can find a known good one and swap it i'd say try it.
Old Apr 12, 2012 | 03:45 PM
B18C5-EH2's Avatar
Former Moderator
Loved
BTW the TW/coolant temp sensor is #13 seen here:
Just a place to start.
BTW:
A fuel pressure regulator is a mechanical part, and likely would not cause come and go symptoms.
Old Apr 12, 2012 | 04:05 PM
Thanks, I always though that was more related to cold start ups, not warm ones.
Can you get away without draining coolant, I assume some will come out.
Do you know the socket size? I will have to get a deep socket for it.
Old Apr 12, 2012 | 09:27 PM
beecee18's Avatar
This is where i'd place my bet!
Old Apr 14, 2012 | 10:27 AM
I just did the ECT anyway, got it cheap. I will give it a few days.
When I took it out I did not drain the coolant, a lot more coolant came out then I thought would.
Old Jul 14, 2018 | 12:40 PM
royalaccord92's Avatar
Did you ever get an answer to your problem? I'm having the same issue only on a restart. Runs fine on the first trip of the day.
Old Jul 15, 2018 | 05:33 PM
tamboo's Avatar
10 Year Member
could be bad engine coolant temp sensor not the gauge sensor.
test while on car to avoid air in the system.
haynes manual has a temp/resistance chart.
check bookfinder/allbookstores/ebay if you need a cheap haynes.
ftrms
Apr 14, 2010 05:58 PM
Ramon96LS
Feb 6, 2010 07:00 AM
mharris251
Classic Hondas
Sep 3, 2008 09:04 AM
LST2
Jan 20, 2008 06:37 AM
screwballz
Feb 7, 2005 12:27 PM
