Suspension & Brakes Theory, alignment, spring rates....
Max front Camber on integra
Old Mar 2, 2012 | 04:57 PM
Superqwak's Avatar
Default Max front Camber on integra
I have a skunk2 camber kit on a 99 integra and i am tierd of burning through tires. I am only cambered in (-) 1 Degree or 1/2. is there any thing some one can suggest to get my car back into alignment?
Old Mar 2, 2012 | 05:15 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Max front Camber on integra
An alignment?
Old Mar 2, 2012 | 05:30 PM
Superqwak's Avatar
Got a alignment already
Old Mar 2, 2012 | 05:33 PM
TypeRfit's Avatar
RESIDENT
What were the specs of your toe in/out
Old Mar 3, 2012 | 05:49 PM
honda.driver.bence's Avatar
toe has alot to do with tire wear, more than camber. you can have 1-1.5 deg neg camber as long as you toed in enough to compensate.
Old Mar 3, 2012 | 06:12 PM
98civdx's Avatar
Master Detailer
You are burning through tires with -1*?!
Post the alignment printout. That amount of camber simply will not eat tires.
I get perfect tire wear at -2*+
Old Mar 4, 2012 | 10:58 AM
bnetkillzone's Avatar
I got -2.9* front camber. Perfect tire wear, just have to rotate tires a little more often.
Most likely toe is out of spec, post up your alignment printout. Before and After.
Old Mar 5, 2012 | 04:31 PM
TunerN00b's Avatar
-1* is the factory specification...
Old Mar 6, 2012 | 05:15 AM
Libertariat's Avatar
Ek Forever y0!
blkcivic310
11
Mar 11, 2010 03:57 PM
qhondak
Suspension & Brakes
Jan 31, 2008 08:07 AM
I got a honda
Sep 8, 2005 07:53 AM
todds94teg
Sep 5, 2003 06:14 AM
spork sport
19
Mar 12, 2002 09:02 PM
