90 integra alignment
Old Sep 7, 2005 | 08:54 AM
I got a honda's Avatar
Default 90 integra alignment
my two front tires look like its positive camber??....i know there is no camber adjustment on this car so what can i do?...just take in a shop?...while a alignment fix this problem? or the toe adjustment??.....please dont tell me it needs camber kits....it is on eibach lowering springs......thank you any help will do
Old Sep 7, 2005 | 09:26 AM
DAguyLS's Avatar
most importantly when it comes to tire wear is your toe. get your toe set to zero.
Old Sep 7, 2005 | 09:43 AM
Default Re: (DAguyLS)
so most likely its the toe thats makin it camber outwards??
Old Sep 7, 2005 | 11:00 AM
DAguyLS's Avatar
you could quite possibly have some negative camber maybe 2degrees, but the toe is why your tires are wearing on the inside
Old Sep 8, 2005 | 07:53 AM
the tires are not wearing out on the inside its the opposite...instead of negative camber it looks like positive camber lets say these are the tires with normal camber wear / \ mine look like this a little bit \ / is that still the toe that has to be adjusted?
alex_s817
Apr 17, 2006 07:51 PM
tekstyle
20
Oct 29, 2004 09:12 PM
todds94teg
Sep 5, 2003 06:14 AM
Shmeek
13
Jul 24, 2002 12:40 PM
spork sport
19
Mar 12, 2002 09:02 PM
