Fan stays on a while after car is off
Old Mar 1, 2012 | 04:40 PM
gqstatus05's Avatar
Default Fan stays on a while after car is off
My friend borrowed my car for a week and he told me that he was at a stop light and the temp gauge rose and the car turned off. He waited 5 minutes and it turned on. He also mentioned that the fan stays on a while after the car is off and then powers off.
Is this a problem with my thermostat?
Old Mar 1, 2012 | 04:44 PM
phootbag's Avatar
Default Re: Fan stays on a while after car is off
You need to diagnose the cause of the temperature increase. This could be caused by an inoperative fan(s), leaking cylinder head gasket, worn water pump impeller, clogged cooling system, malfunctioning gauge combined with a separate stalling issue, or faulty ECT and temp sending unit, low or contaminated coolant or a myriad of other things.
It could be caused by a thermostat. But without diagnosing the problem your guess would be as good as anyone elses.
Old Mar 1, 2012 | 05:52 PM
gqstatus05's Avatar
I will drive it tomorrow and post back here.
Old Mar 2, 2012 | 08:10 AM
JerseyAccord's Avatar
if it stays on after the car is turned off only for a min or so thats normal and nothing to worry about, if it is on and will not shut off the relay is likely stuck (happened to me). the relays for the fans hang near the left side (drivers) of the engine bay right next to the AC fan
Shidou
Sep 16, 2016 06:49 AM
MrBigMac
Honda Civic (2001 - 2005)
May 15, 2016 04:25 PM
Driven
Oct 22, 2009 06:39 PM
JoeCereghino
17
Nov 30, 2008 08:41 PM
liznadrian
Oct 22, 2008 07:45 PM
