s300 in auto p28
is it fine to run the ecu with automatic components still intact in a manual car.
and it has a s300 installed in it already.
or do i need to desolder the components for it to be able to run it?
The ecu does not care about the IC transistors.
As I said before. Don't waste your time with it unless you are throwing a code 19.
plugged it in and couldn't install the s300 to laptop.
got the Smanager, but still no luck.
looked at the device on the lap top and it was throwing code 28.???
does it need to be converted than???
Converting the ecu to 5 speed has absolutely nothing to do with the USB driver or Smanager.
The s300 will function with an automatic or manual p28.
Read the Smanager help file. Read the section on usb driver.
You really should have just bought the system brand new from an authorized dealer to prevent these headaches.
I would never recommend buying a used s300. Especially because of this: http://www.hondata.com/s300_counterfeit.html
yea i checked and it wasn't a counterfeit. Its legit.
read up the usb driver and everything is fine, but still can't install it onto my laptop.
could it be my firewall???
found out that i was using the older version.
just got done downloading the new version, so ill give it a go tomorrow morning.
and found out that ill need to update the usb drivers.
ok, i'm sorry for putting you guys in this situation, but i finally got the USB driver installed.
I tried doing it the way Hondata had it in the USB trouble shot guide line, but that didn't work. Tried it manually and typed down (c:\program files\Smanger) and didn't work, and than i tried it manually again and typed down (c:\program files\86x\Smanger) or something like that and it worked.
thanks for all your help too.
now i gotta go apologize to the guy who sold me the s300.
vtecjj
Feb 20, 2004 01:00 PM
redline201
Feb 10, 2003 08:32 AM
