B18c4 Starting problems help
Old Feb 29, 2012 | 01:35 PM
fire_king's Avatar
Default B18c4 Starting problems help
Hi hope someone can help with this
Went to start the car and it didnt start it ticks over and thats all its doing doesnt even try to start what so ever no coughing or spluttering at all. I have checked for spark fuel which are fine also replaced dizzy cap coil igniter leads spark plugs fuel filter checked injectors and still having the same issue. I have also tried spraying easy start but that did not make a difference at all. The car was working fine 10 minutes before this happened. Fuel pump is also priming
Thank in advance
Old Mar 7, 2012 | 06:05 PM
da9bigboi's Avatar
Default Re: B18c4 Starting problems help
probably your battery...or since this post has been over a week you probably got your car started already...
Old Mar 8, 2012 | 02:45 PM
fire_king's Avatar
Still not sorted the problem changed the battery still nothing car is ticking over but just wont start. Timing is also good any other ideas?
PinkMaggit
16
Nov 28, 2008 05:25 PM
vinuneuro
Oct 12, 2006 05:44 AM
93egsi
11
Jun 18, 2004 05:37 AM
Honda Sport
Jun 4, 2003 05:27 PM
si00000
Nov 1, 2001 06:10 PM
