anyone know wha theses are (H22A4)
Old Feb 28, 2012 | 06:25 PM
JusAccord's Avatar
Default anyone know wha theses are (H22A4)
Anyone know what that connector connects to? its black on the outside and blue in the inside, i've looked everywhere around the engine to see wha it would connect too, no luck and also is that little ground wire suppose to attach like that?
Old Feb 28, 2012 | 06:26 PM
JusAccord's Avatar
Default Re: anyone know wha theses are (H22A4)
H22a4 engine 1999 honda prelude
Old Feb 28, 2012 | 06:31 PM
snobordboy's Avatar
Moderator
The ring is oil pressure sender, and first thought on the plug is front O2 sensor.
Old Feb 28, 2012 | 06:32 PM
zelseman's Avatar
The ring on the oil pressure sending unit should be either screwed into the end of that stud or bolted on. It will throw a cel if you leave it off.
Old Feb 28, 2012 | 10:39 PM
gstrudler's Avatar
Are you throwing any CEL? Front o2 should be 4-wire, so not that. 2 wire could be an aftermarket oil temp sensor since it's right next to the oil filter, or possibly stock oil pressure sensor (should be throwing a CEL though).
Old Feb 28, 2012 | 11:48 PM
pentaq's Avatar
The plug looks OE. I suspect it's one wire and goes to knock sensor.
Old Feb 29, 2012 | 04:06 AM
spoolinlude's Avatar
I live under a rock
Knock is a round connector, my guess is some random evap solenoid or something, or under the intake manifold. All of the temp sensors are round connectors as well.
Is it the VSS? Can't remember how many wires that connector is. The VSS is located on your transmission, see if you've got any open connectors on top of the trans.
Old Feb 29, 2012 | 06:17 AM
snobordboy's Avatar
Moderator
That was my thought from the loaction as well, but every one of those that I have seen is round.
Another thought, is this car, or was it, an SH?
Old Feb 29, 2012 | 07:55 AM
Apex1972's Avatar
http://www.drivewire.com/vehicle/199.../knock-sensor/
obd2 knock sensor plug is not round.
Old Feb 29, 2012 | 02:30 PM
JusAccord's Avatar
That wire is not long enough to go on the trans, it can b a o2 sensor, ima do some reseatch jus wanna get some ideas from yall so I know wha to look for,
Old Feb 29, 2012 | 02:37 PM
JusAccord's Avatar
its the base model
Old Feb 29, 2012 | 02:40 PM
JusAccord's Avatar
And I dont see anything unplug im jus missin a sensor or something
Old Feb 29, 2012 | 02:43 PM
JusAccord's Avatar
Wha is cel?
Old Feb 29, 2012 | 03:27 PM
asianpoet's Avatar
http://www.ebay.com/itm/New-Knock-Se...item3f099d1538
Im thinking knock sensor..... right above the oil filter
Old Feb 29, 2012 | 03:33 PM
JusAccord's Avatar
yea it looks like it connect to that
Old Feb 29, 2012 | 03:37 PM
JusAccord's Avatar
how can i bolt it in becuz its jus hanging like that
Old Feb 29, 2012 | 05:25 PM
JusAccord's Avatar
the o-ring to the oil pressure sensor
Old Mar 1, 2012 | 03:28 PM
JusAccord's Avatar
ok its the knock sensor, i already installed it thanks! now how am i suppose to bolt this ring (sender) onto the oil pressure sensor, im missin something...
Old Mar 1, 2012 | 11:17 PM
gstrudler's Avatar
Find out the thread size of that stud and buy two nuts for it. Take the ring off, put one nut on and thread it down most of they way, put the ring on, then put the other nut on and thread it down on top so it sandwiches the ring in place.
Old Mar 2, 2012 | 03:32 AM
pentaq's Avatar
haha, I was right.
Old Mar 4, 2012 | 02:41 PM
JusAccord's Avatar
Yea but how its suppose to thread on like that, where u think I can find that, autozone etc..
Old Mar 4, 2012 | 06:40 PM
v4lu3s's Avatar
RTFM
that oil pressure sensor is from another car with a push on connection, like a civic or integra. the prelude/accord one is different and has a machine screw that holds the ring to the sensor.
Old Mar 5, 2012 | 02:43 PM
JusAccord's Avatar
yea i jus found that out, stupid me, i forgot this engine was in a civic, so i was missing some sensors, i jus bought the right oil pressure switch and a knock sensor cause it didnt have one...now yall got me looking around the enigine for more mistakes LoL
Old Mar 5, 2012 | 04:06 PM
Wing8806's Avatar
For future reference, CEL = check engine light
Old Mar 14, 2012 | 09:23 AM
ek_da_car's Avatar
I agree the one wire is the knock sensor. I believe the other on is to the iab solenoid. Check the wire colors...
jdubEP3
Jan 26, 2012 05:23 AM
Red_ED8
Nov 19, 2007 06:26 AM
thelate1
Jun 23, 2007 09:38 PM
LiLOtaku
Aug 20, 2003 06:16 AM
takeheed
Sep 18, 2002 11:27 AM
