Suspension & Brakes Theory, alignment, spring rates....
Progress Technology CS2 Problem
Old Feb 28, 2012 | 07:47 AM
iNfAmOuS_E46's Avatar
Default Progress Technology CS2 Problem
I have it threaded a little above halfway maybe half way up the sleeve and i cant go higher wtf do i need a spring compressor ???
it sits way too low
Old Feb 28, 2012 | 08:08 AM
GagnarTheUnruly's Avatar
Default Re: Progress Technology CS2 Problem
No just moar powar
Did you loosen the allen bolt that tightens the collar? Are you using the coilover wrench correctly. With a little elbow grease you should have no problem moving the collar up even with the coilovers on the car.
Old Feb 28, 2012 | 08:38 AM
grumblemarc's Avatar
The Grumpiest
Brute force! That's what I had to do. Hit the threads with some WD-40. Might help.
Old Feb 28, 2012 | 08:47 AM
x2
Old Feb 28, 2012 | 03:30 PM
Originally Posted by GagnarTheUnruly
No just moar powar
It was hard as hell even when I installed them
Old Feb 28, 2012 | 08:05 PM
The Grumpiest
It wasn't that hard. You should start working out.
Old Feb 29, 2012 | 04:38 AM
Libertariat's Avatar
Ek Forever y0!
Didn't have any problem installing mine:
Old Feb 29, 2012 | 05:52 AM
tron_'s Avatar
10 Year Member
Make sure the threads are clean, like mentioned above use some WD-40. They shouldn't be THAT hard to turn but if they are, get your girlfriend to help
Old Feb 29, 2012 | 11:10 AM
STOCK_SOHC_DX's Avatar
Sig worthy
Old Feb 29, 2012 | 02:03 PM
I work out and im no small dood by any means
Just dont want to break anything
Old Feb 29, 2012 | 05:54 PM
The Grumpiest
Doubtful you can do that.
Old Mar 2, 2012 | 12:16 PM
Tyson's Avatar
Take off the top nut, jack up the chassis, raise the perch, carefully lower the chassis, tighten nut. That's as high as you'll get without any extra preload.
Old Mar 2, 2012 | 03:42 PM
92cxhatch169's Avatar
Just dont want to break anything[/QUOTE]
only thing your going to break is your knuckles
young geezer
May 27, 2010 06:11 AM
fms1day
Suspension & Brakes
Jun 24, 2005 07:20 AM
5spdIntegra
Sep 17, 2004 02:23 PM
chrisb
Mar 28, 2003 10:21 AM
E. Honda
21
Jul 18, 2002 09:36 AM
