eg wire tuck and fuse box relocation
Old Feb 27, 2012 | 09:43 PM
killemall18535's Avatar
Icon2 eg wire tuck and fuse box relocation
I'm doing my first wire tuck on my ej1 so far I have pulled everything off the front end and pulled the heater core and blower motor out to figure out a good relocation spot for my fusebox any advice on where to put it bc I need my heater and I was thinking somewhere above the ecu is that good?
Old Feb 28, 2012 | 02:42 AM
morbius18's Avatar
Default Re: eg wire tuck and fuse box relocation
I pulled my ecu and bracket off and put the fuse box in the little hole there and have the ecu to the left kinda under where the ac condenser used to be. Check my thread in my sig, i have a few pics of it.
Old Feb 28, 2012 | 06:17 AM
delsolo95's Avatar
i put mine where the passenger air bag is. took the air bag out and unbolted it from the airbag tray. of course dont put it there if you need air bags.
Old Feb 28, 2012 | 11:14 AM
That's what I was going to do is relocate where the ecu goes I think that would be the best access point for it as well
Old Feb 28, 2012 | 12:23 PM
apexi_rsx's Avatar
mines located in my glove box...easy acess there too.
Old Feb 28, 2012 | 12:29 PM
Blasney's Avatar
From: On the road...generally in the central United States...
It depends on how accessable you want it to be, and how flexible you are. Inside the glove box is probably the most user-friendly location, or...if using a trunk-mounted battery (coupes), I've installed them in the back also. Makes for a long harness, but if doing it all from scratch, it's no big deal. It keeps the box out of sight, but still easily accessable when needed.
Old Feb 28, 2012 | 12:49 PM
cvcrcr99's Avatar
I plan on putting mine in the trunk or in the glove box when the time comes for my battery/fuse box relocation.
Old Feb 28, 2012 | 01:58 PM
Well how does the glove box work do u take out the insert and mount to the frame
Old Feb 28, 2012 | 02:55 PM
apexi_rsx's Avatar
i cut a small hole in the back of the glove box to pull the wires through. it was a tight fit to plug them in but its definitely possible without cutting or splicing any wires. you will have to pull all the wires through and get as much slack as u can.
Old Feb 28, 2012 | 03:13 PM
Ok well that sounds like I would rather put it where the ecu is supposed to be
Old Feb 28, 2012 | 04:24 PM
Thanks for the ideas everyone ill post pics of my progress as soon as I can
Old Feb 28, 2012 | 08:15 PM
So does anyone know how much extra wire I should have for the wire tuck its going through the fender supports and is almost long enought
Old Feb 29, 2012 | 01:19 PM
delsolo95's Avatar
you shouldnt have to extend anything if you did it right except a few wires like the horn, headlights, and i forget maybe the ac harness as well.
Old Feb 29, 2012 | 03:20 PM
Ok so I only need to do the headlights then bc I don't have a horn or ac so where is everyone locating the plugs for the engine harness?
Old Mar 1, 2012 | 08:10 AM
delsolo95's Avatar
radiator fan plug needs to extend too
Old Mar 1, 2012 | 08:12 AM
delsolo95's Avatar
everyone is routing the engine harness through the firewall under the heater core outlet and inlet pipes. here check this out https://honda-tech.com/forums/honda-acura-28/shaved-tucked-customized-engine-bays-pics-theory-discussion-1693934/
Old Mar 5, 2012 | 09:36 AM
Oh ok well that sounds right I like all the ideas and ill ask more questions as I progress
Old Mar 7, 2012 | 09:42 PM
What guage wires should I run for the one from the fusebox to the battery cable
Old Mar 7, 2012 | 10:36 PM
jbpnoman's Avatar
4 or 2g is fine.
Old Mar 9, 2012 | 06:39 AM
delsolo95's Avatar
heres my diagram
you dont really need a distribution block, i just put one in case i needed to disconnect something. and i ran a 6 guage wire from the fuse to battery cable not an 8 like my diagram says
Old Mar 9, 2012 | 07:36 AM
jjmose03's Avatar
Nice diagram!
Old Mar 10, 2012 | 07:02 PM
I like the diagram yeah looks like what I need
Old Mar 10, 2012 | 07:37 PM
Alfa Q 4.0's Avatar
I did a total rewire and put all fuse boxes in the trunk..
It was more work but looks very clean.. I will fine my pics and post them up soon.
Old Mar 10, 2012 | 08:01 PM
little rookie's Avatar
I just started the wire tuck on my ej1 today I was going to use an oddessy battery where the pass air bag goes and wasn't sure if the fuse box would fit next to it but I kinda like the idea of putting it wher the ecu goes. Eather way keep us posted on the progress
Old Mar 11, 2012 | 09:24 AM
I already have done the wire rerouting now I'm doing some body work to the front core support before I further my process and I'm going to mount the fusebox where the ecu goes and take out the ac condensor so I can put my ecu there. Does anyone know where I can find these plugs for my firewall and hopefully cheap??
