Axle Nuts won't come off - Ive broken 4 1/2 breaker bars and torched them
Old Feb 27, 2012 | 02:03 PM
Deej23's Avatar
Default Axle Nuts won't come off - Ive broken 4 1/2 breaker bars and torched them
Is it at all possible that my axle nuts on my 92 EG8 are reverse thread???
Ive broken 4 1/2 breaker bars and used PB Blaster and torched them and still won't budge!
Im honestly just about to cut the nuts off!
Old Feb 27, 2012 | 02:06 PM
Civic2Fast's Avatar
Default Re: Axle Nuts
nope they are standard thread... I've done the same thing several times... you need to hit it with a really good impact... if the car is still driveable, just take it to a shop, have them turn up the torque... and get ready to watch sparks fly as the rust breaks down
Old Feb 27, 2012 | 02:10 PM
Deej23's Avatar
Ya its not drivable anymore! Thats the last step for me to ****** it out!
Its so insane how impossible those things are to get off sometime
Old Feb 27, 2012 | 02:29 PM
Mashimaro's Avatar
a good impact gun will usually blast those off without much problem.
good luck OP!
Old Feb 27, 2012 | 03:59 PM
Civic2Fast's Avatar
I've been right there with you... it's a pain in the *** but if you can't get it and need it off... you may pulling your spindle and hitting a shop... I've broken at least 20 1/2" drive ratchet/breaker bars in the past...
Old Feb 27, 2012 | 05:00 PM
hannslebo's Avatar
Desperate much? L0L...
I told you they were standard!
Old Feb 27, 2012 | 05:36 PM
JDM-sol 89's Avatar
Are you using quality tools?
Can't break mine though! lol, that one day working on your ef hatch we had my craftsman breaker bar and the 4ft handle off the floor jack. still didn't break that thing. Thing has some proper "seasoning"..
Old Feb 27, 2012 | 05:39 PM
Civic2Fast's Avatar
lol isn't that the one with the twisted head??
Old Feb 27, 2012 | 05:56 PM
JDM-sol 89's Avatar
YES!! I have no idea how it still breaks anything loose.
I just want it to break already so I can go get a new one
Old Feb 27, 2012 | 06:02 PM
Civic2Fast's Avatar
Go help the poster out... sounds like his axel nuts will finish her off hahaha
Old Feb 27, 2012 | 06:05 PM
94EG8's Avatar
Seagull Management
Get a 3/4 drive and set and try that.
Old Feb 27, 2012 | 06:25 PM
Deej23's Avatar
Ya i know that would do the trick but i can keep returning these 1/2 and get another one each time they break! We finally got one side off now just another 10 breaker bars and I'm sure ill get it lol!!
Old Feb 27, 2012 | 06:26 PM
Deej23's Avatar
You know I'm desperate! your right there beside me each time they break!
Old Feb 27, 2012 | 07:45 PM
ek4_b16a's Avatar
Get and use better quality tools and you won't have to deal with this issue any more.
Old Feb 27, 2012 | 07:50 PM
98civdx's Avatar
Master Detailer
What kind of breaker bars are you using?? Are you using a cheater pipe?
I normally can get them just with my HF bar no problem.
Old Feb 28, 2012 | 06:53 AM
Red_Army's Avatar
go to harbor freight or northern tools if you have one. pick up a decent air gun(mine was 150.) spray em with liquid wrench, get an actual axle nut socket and hit that thing till they fly off. i broke 1 breaker bar with a 7 foot extention(go big or go home im lazy.) before trying that. ball joints are a bigger pita then this usually is.
Old Feb 28, 2012 | 08:59 AM
axis11's Avatar
OP, have you tried using a hammer instead of long extension pipes. Using a standard socket and a fixed handle about a foot long, give it fast swings of a medium sized hammer. It might take a dozen or more blows but it will shake it loose. Worked for me everytime and never broke anything.
Old Feb 28, 2012 | 10:46 AM
WhiteOnRice's Avatar
Just bring the whole knuckle and axle into a shop. I've had to do it before and they had to bust out the "big boy" impact they said they hadn't used in 10 years.
Old Feb 28, 2012 | 11:28 AM
Former User's Avatar
Did you raise the axle nut locking tab?
Old Feb 28, 2012 | 12:19 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Default Re: Axle Nuts won't come off - Ive broken 4 1/2 breaker bars and torched them
^^^ I wasn't able to raise the tab completely but I used a 4' 3/4" steel pipe with my 1/2" craftsman wrench. I applied pressure to the point the pipe would flex 6-8" and released and did that about three times before putting some real force into it. It worked like a charm for me.
It is a method used in the auto body world to pull damaged areas back out. If I remember correctly it causes the atoms in the metal to become more mailable and less likely to fracture and break something.
I have since purchased a refurb. dewalt 1/2" electric impact wrench off ebay for $125. I love it for suspension components.
Or a dremel and new nuts!!!
Old Feb 28, 2012 | 01:11 PM
Civic2Fast's Avatar
Tell that the snap-on, craftsman, and matco breaker bars I've destroyed lol
Old Feb 28, 2012 | 01:25 PM
98civdx's Avatar
Master Detailer
I've broken 2 snap on's and 1 craftsman. **** happens, and **** breaks.
Old Feb 28, 2012 | 01:44 PM
HondaPartsHero's Avatar
Technical Hero
take off spindle, drive to shop with good impact, tip the guy $10
Old Feb 28, 2012 | 02:28 PM
ksjohnsonEK09's Avatar
If they are that seized on there you are probably better off getting a wizz wheel and cutting them. Grind a notch on both sides to where you can just barely see the threads stating to show, then hit it at an angle with a chisel. It will pop right open. I would suggest running a die or thread file on the axle and use a little anti-sieze when you put them back on.
WhiteOnRice
39
Jun 11, 2011 06:14 PM
SoTexDC2
Jun 22, 2007 06:05 PM
tonesdef
15
Jul 26, 2003 06:28 AM
6.5inCivic
33
Aug 6, 2002 11:45 AM
KrashZer0
May 26, 2002 02:47 PM
