high idle lacking power oil out of exhaust ports
I have a 94 boosted b16 hatch. I let it sit for a while went to drive it one day and it sounded like it had a misfire and was lacking power, also had oil coming out of exhaust port. It has 89k on the motor. I replaced plugs cap wires rotor distributor fuel filter adjusted the valves. And now out of nowhere it gained a high idle. No ticking or knocking. Also found pieces of metal in oil pan. Help please
i blew a turbo in my saab and when it went, it sucked my engine dry. it could be a bad turbo but sounds like rings are the culprit. check for play on the turbo and as the other poster stated do a compression test
hondaeg8
Jul 21, 2004 03:32 PM
RuthlessEF-9
Jun 25, 2003 10:36 AM
