code 14... i think
Old Feb 26, 2012 | 03:13 PM
richard78's Avatar
Default code 14... i think
got a 93 4 door lx(non vtec)shell. just installed a used eng/tranny(auto). after every was connected to the eng(except the exhaust system), i wanted to make sure it started and ran before i started on the tranny side. though it was loud(no exhaust) the eng idle was good(800-1000rpm) and revved good. finished on the tranny side and exhaust. now it wont stay running unless u give it throttle. and now it sounds like it has a knock. CEL is on. this is how the light flashes: 3 sec on, 3 sec off, 2 sec on followed by 4 quick flashes. i have checked the bat voltage to the iav sensor(12.1v) and ohmed out the iav(13 ohms). according to the repair manual, these are good readings. anyone have any suggestions, thanks.
Old Feb 26, 2012 | 03:28 PM
Former User's Avatar
Default Re: code 14... i think
Post a video of the CEL blinking. It's best not guess what code you have.
Old Feb 26, 2012 | 03:41 PM
Dc4LsTeG's Avatar
EK9
X2 I can't even understand how your trying to explain how your cel is blinking
Old Feb 26, 2012 | 04:33 PM
richard78's Avatar
http://youtu.be/Ot9T4xz2fro
Old Feb 26, 2012 | 04:39 PM
Codes 10 and 14.
Reset the ECU and run the engine briefly to see if both codes repeat.
Old Feb 26, 2012 | 04:41 PM
richard78's Avatar
i did, they did
Old Feb 26, 2012 | 04:45 PM
What wire colors do you see in the IAT sensor and IACV connectors?
Old Feb 27, 2012 | 01:40 PM
richard78's Avatar
Old Feb 27, 2012 | 04:55 PM
richard78's Avatar
does this look right?
Old Feb 27, 2012 | 05:25 PM
The bottom picture appears to be the IAT sensor. If so, the wires are correct.
If the middle picture is the EVAP purge control solenoid, then those wires are also correct.
What is the top picture? The IACV should have Yel/Blk and Grn/Wht wires.
Old Feb 27, 2012 | 06:12 PM
richard78's Avatar
yes the top is the IACV. looks to be yel/blck and bl/yel. if that is wrong then im not sure where the right connector is.
Old Feb 27, 2012 | 06:25 PM
Any signs of cut and spliced wires for the IACV?
Old Feb 27, 2012 | 06:31 PM
richard78's Avatar
nope. everything looks stock
Old Feb 27, 2012 | 06:45 PM
With the key in ON(II), does the IACV Yel/Blk wire have battery voltage?
With the key in ON(II), does the IAT Red/Yel wire have 5 volts?
What's the resistance across the the two terminals of the IACV and IAT?
Old Feb 27, 2012 | 06:49 PM
richard78's Avatar
i'll have to recheck the voltages but i remember the resistance being within the 8-15 ohm range.
Old Feb 27, 2012 | 06:51 PM
This^ is the IACV, right? Also resistance test the IAT.
Old Feb 27, 2012 | 06:56 PM
richard78's Avatar
ok. i'll check those tomorrow
richard78's Avatar
and yes that was the iacv
Old Mar 3, 2012 | 12:34 PM
richard78's Avatar
been really busy this past week and havent had time to work on this thiing till today. i took out the IAT sensor and half of the plastic tip looked to be melted exposing the wires. i replaced it and it now starts and idle, but there is a knocking noise coming from the engine and it idles very rough with lots of vibration. no CEL.
Jareeb
30
Jun 12, 2015 02:12 PM
I want to be in your sig
Nov 3, 2009 09:06 PM
Darkane
Jun 18, 2008 07:21 AM
ActiveAero
Jan 18, 2002 11:14 PM
