Where are the speaker wires in the rear of civic???
Old Feb 26, 2012 | 04:19 AM
bee743's Avatar
Default Where are the speaker wires in the rear of civic???
My son's trying to run a amp and subs,but my civic didn't have and rear speakers-I thought that was odd-but thought that it was only an option when purchased.there are no wires accessable in the rear.its a 1999 honda civic ex model.is this model per-wired for rear speaker installation??we wanted to hook wires from the rear to his subs.is there any way to run wires from the radios wire harness to the rear to have rear sound??
thanks for any info.
Old Feb 26, 2012 | 04:24 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Where are the speaker wires in the rear of civic???
You run the subs from the amp so the speaker wires you're looking for are not needed.
94EG8's Avatar
Seagull Management
The wires are there, the plugs will be taped to the harness near where the rear speakers would go. I wouldn't use those wires for amp and subs though, they're only 22 gauge.
Old Feb 26, 2012 | 04:30 AM
bee743's Avatar
thanks-but he wanted to add rear speakers in the back-I would just need to find the speaker connections but dont see any available-do the wires come under the back seat? or by the rear quater panel?
Old Feb 26, 2012 | 04:40 AM
The Grumpiest
You have to search for them. They are there unless the previous owner removed them. Look closest to the rear speakers first.
Old Feb 26, 2012 | 04:45 AM
94EG8's Avatar
Seagull Management
If it's an EX then it's a either a coupe or sedan. They will be up under the rear deck.
Old Feb 26, 2012 | 05:17 AM
MRGRIM's Avatar
R.I.P. Mark
hes after the rear wire for high level input into the amp as aposed to using rca like an after market head unit
and yes you can do that
Old Feb 26, 2012 | 05:25 AM
The Grumpiest
No kidding. You're assuming he's talking about a stock headunit as opposed to aftermarket, which wasn't mentioned.
Old Feb 26, 2012 | 09:10 AM
bee743's Avatar
thanks for all the help-you were exactly right,they were stuffed behind the carpet area-thanks again
Old Feb 26, 2012 | 09:18 AM
98civdx's Avatar
Master Detailer
I have a question, why not run RCA's? You will be better off.
Old Feb 26, 2012 | 09:22 AM
EsotericImage's Avatar
Retired Moderator
Cuz that would make too much sense!
Old Feb 26, 2012 | 09:24 AM
98civdx's Avatar
Master Detailer
lol The only thing I could see them being used for is run a line out converter.
Old Feb 26, 2012 | 09:36 AM
The Grumpiest
I think they're installing amp, subs and rear speakers. The OP never said anything about using the high levels inputs.
Edit. But he did say he wanted to hook the speakers to the sub. RCAs all day.
Old Feb 26, 2012 | 11:44 AM
94EG8's Avatar
Seagull Management
The OP made another thread looking for a radio code for the stock stereo code so I'm guessing that's why, there are no RCA outputs on a stock headunit.
That said I'd probably spend the money on a better headunit and some half decent 6.5" round speakers for the front and worry about the rest later.
Old Feb 26, 2012 | 12:13 PM
98civdx's Avatar
Master Detailer
I didn't see that.
But, I agree, I was half way wondering why there is no rear speakers.
A decently priced Alpine HU, and some infinity speakers will do wonders, without an amp.
cnowak
May 24, 2011 09:38 AM
EF-ingB16
Audio / Security / Video
20
Sep 3, 2010 10:37 PM
egvtec
Jan 16, 2009 05:56 PM
Jizzmaster Zero
May 19, 2006 09:42 PM
serious
Apr 18, 2002 03:01 AM
