.:boosted d16:..: erratic idle:.
Old Feb 25, 2012 | 06:24 PM
Daltonamo's Avatar
Default .:boosted d16:..: erratic idle:.
what tiz up ht
i just finished turbo'ing my d16y7 and now im getting a erratic but pattern like idle.
the car will fire rite up and idle at 700...then build to 2700...then back down to 700 etc. etc.
i swapped my d16y7 manifold to the y8 99-00 auto version (my car isnt auto)
i have plugged off the port for the pcv valve...for catch can and stuff
any idea? iacv, tune, i can post pics of the manifold and a video of idle if necessary
thanks
Old Feb 26, 2012 | 03:05 AM
grumblemarc's Avatar
The Grumpiest
Default Re: .:boosted d16:..: erratic idle:.
Is it tuned? Are you throwing a CEL?
Old Mar 4, 2012 | 04:05 PM
Daltonamo's Avatar
well i traced the source of the issue and i cant believe i didn't think of it. when i did the turbo installation part of the set up on my 97 d16y7 engine was a 99y8 intake manifold swap. I used the y7 throttle body and the iacv is built on to the y7 throttle body and is allowing too much air to pass through. i now have a gsr tb and my idle is now somewhat efficient. i now need to convert to a 2-wire iacv. i have one but the auto y8 doesnt have the ports for it to mount on the back of the intake manifold. idk if anybody has decided to go through the hassle of making this work but i cant figure how im going to make the iacv work on this manifold without drilling and tapping into it. but im not sure where to tap in. a little direction would be appreciated.
Old Mar 5, 2012 | 03:53 AM
The Grumpiest
And NONE of this was mentioned in the first post. Marvelous.
Leviatard
18
Oct 30, 2014 09:28 AM
snatch
40
Mar 29, 2011 01:25 PM
Jakester9500
Nov 16, 2008 02:30 PM
97ekcoupe
Mar 18, 2007 09:32 AM
schpiel
Dec 13, 2006 06:19 PM
