95 civic dx/B18b1 won't start
Old Feb 25, 2012 | 04:12 PM
dalebly50's Avatar
Default 95 civic dx/B18b1 won't start
HI Im new to the form and need help bad i have a 95 civic dx that sat for 2 years before i swaped a b18b1 into it now it wont start have fuel spark and compression. timing is dead on all grounds are right it cranks if i play with the throttle it will spit and spuder It will run for a little bit on starting fuild plz help have been fighting this car for 2 weeks also one of my buddies that "knows" HONDA'S installed new ECU plugs for me when we did the swap thanks
Old Feb 25, 2012 | 04:23 PM
grumblemarc's Avatar
The Grumpiest
Default Re: NEED HELP PLEASE!!!!!!!!!!!!!!!
What color is the spark?
Old Feb 25, 2012 | 04:28 PM
dalebly50's Avatar
blueish white also just noticed the 3rd brake light is on
Old Feb 25, 2012 | 04:32 PM
spoolinb18's Avatar
I had the same probablem. I just put my engine back into my teggy and it would turn over but wouldnt start. I checked my thermostat ground and saw it was loose. I tightened it up and it started right away. I know you said your grounds were good but check it. It saved me
Old Feb 25, 2012 | 04:39 PM
00_EKHatch's Avatar
If it will run with starter fluid then it's fuel related most likely, Did you put fresh gas in it?
Old Feb 25, 2012 | 04:44 PM
dalebly50's Avatar
yea fresh gas and the ground at the thermostat is good spent 3days checking all grounds
Old Feb 25, 2012 | 04:53 PM
Former User's Avatar
Default Re: 95 civic dx/B18b1 won't start
Thread titles MUST summarize the tech problem so that members browsing titles can easily understand the problem without reading the post -- Title edited.
Old Feb 25, 2012 | 08:56 PM
dalebly50's Avatar
O my bad. RonJ u got an idea
Old Feb 26, 2012 | 01:52 AM
00_EKHatch's Avatar
Okay, did you check your fuel pressure?
Big Boi B
18
May 12, 2012 09:39 PM
redsi89
Sep 10, 2008 06:55 AM
jwhella
May 7, 2007 07:54 PM
