Need help readjusting EJ6 Timing Belt
Old Feb 23, 2012 | 03:17 AM
Jabuuty671's Avatar
Default Hard time getting timing belt back on
edit: EJ6 Sedan w/ D16y7
Changed my Head Gasket because it was blown and now I need to fix the timing.
Before I took off the head; the Crank was at the middle red timing mark, not the white TDC on the far right and still is (the picture is used for reference, I found it on one of the many tutorials I have bookmarked that I just don't quite understand) (Picture LINK)
The Camshaft was at UP, and is again that I've reinstalled it.
and the distributor is facing the #1 Spark Plug.
-I don't have a Timing Light/Gun
-I don't have a tool(s) to get the crank pulley off nor will I take it off.
What do I do?
Also; how would I go about getting to the tensioner? Taking off the driver side motor mount and pulling off the lower timing belt cover, or can I just slip a socket right in (from what I heard I don't have to)?
Old Feb 23, 2012 | 04:15 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Hard time getting timing belt back on
Loosen the tensioner.
Old Feb 23, 2012 | 05:06 AM
Jabuuty671's Avatar
I didnt want to have to take off the bottom timing belt cover... Way too late now, already midnight.
Any alternative for me to try tomorrow? All I need is to put on the darned timing belt; im gonna change it next week anyways.
Old Feb 23, 2012 | 08:16 AM
NVturbo's Avatar
O.G. triple O.G.
The old belt came off easy because it was STRETCHED. Loosen the belt tensioner and put the belt back on. Rotate the motor (by hand) one entire revolution just to make sure everything is back to TDC.
Old Feb 23, 2012 | 08:44 AM
dpetro1's Avatar
you should be able to access the tensioner without removing the cover. there is a grommet over the bolt, pop it out and loosen the tension
Old Feb 23, 2012 | 08:49 AM
D16SiHatch's Avatar
^yep, and if you removed that belt without first loosening the tensioner then i hope you had to pry it off cause if it came off easily then it has slack in it and should probably be replaced.
Old Feb 23, 2012 | 09:01 AM
98civdx's Avatar
Master Detailer
Old Feb 23, 2012 | 12:37 PM
Jabuuty671's Avatar
Not necessarily easy, almost lost my fingernails in the process lol.
Rotate the crank another 360 degrees until it's back to the TDC mark?
I'd need to remove the upper driver side motor mount first though, right?
I tried removing the bolt on the right side for the lower timing belt cover, and a super long bolt on the left side of the engine towards the power steering pump (keep in mind i'm facing the camshaft from the driver fender) and now that super long bolt (which was next to the dipstick housing) isn't fitting back in it's place where I pulled it.
Yeah, had to pry it off.
Old Feb 23, 2012 | 01:52 PM
NVturbo's Avatar
O.G. triple O.G.
Yes, whenever you remove or Install a timing belt, you have to loosen the belt tensioner. I rotate the motor (counter-clockwise) after the belt is on, tensioner tightened.....just to make sure all is correct. Timing perfect every time.....
Old Feb 23, 2012 | 01:59 PM
dk=gsr's Avatar
you should be able to excess the bolt with a short 14mm socket and a socket.
it should be fairly tight but you should be able to do it.
Old Feb 23, 2012 | 04:22 PM
Veece's Avatar
Hit up a Search on "replacing my timing belt", or something similar
Old Feb 23, 2012 | 05:56 PM
Texas4door's Avatar
I did the same thing as you when taking it off, just slid it off.
I put it back on by having my bro haul the belt edge up onto the cam gear while I rotated the crank gear to pull the belt onto the cam (I didn't know about the grommet in the timing cover at the time or I woulda just done that XD; )
Just make sure you mark the cam gear and belt teeth so the belt goes back on without skipping a tooth!
Old Feb 24, 2012 | 06:51 PM
Jabuuty671's Avatar
Default Need help readjusting EJ6 Timing Belt
EJ6 Sedan w/ D16y7
What do I do?
Old Feb 24, 2012 | 07:56 PM
Former User's Avatar
Default Re: Need help readjusting EJ6 Timing Belt
Only one thread is allowed per topic. Related threads merged.
Old Feb 24, 2012 | 09:48 PM
Jabuuty671's Avatar
Bump ... Need to get this done.....
Old Feb 25, 2012 | 04:39 AM
The Grumpiest
Will be near impossible since you stated what you WILL NOT do and DO NOT have.
Old Feb 25, 2012 | 04:52 AM
Jabuuty671's Avatar
I can have it re-timed at an automotive class at my school but I just need to get the car running to take it there. Putting the timing belt on isn't only what i'm worried about but how precise it should be on like; Distributor, Cam and Crank positions because it may have been messed up. I want to get the timing belt to the most precise timing i can without pulling out the crank pulley or using a timing light/gun; and have it worked on at school where there are the correct tools and where my timing belt, water pump and tensioner will be changed with new ones.
Simply; I just want to get the car from point A to point B so said Point B can fix all the timing problems.
Old Feb 25, 2012 | 05:01 AM
The Grumpiest
Whatever YOU need to do that gets it done. If you need to remove the mount then do it. Doesn't take that long to do and TBH you could have done it by now.
Old Feb 25, 2012 | 05:04 AM
Tow don't drive your car.
Old Feb 25, 2012 | 05:08 AM
The Grumpiest
That would be the best option.
Old Feb 25, 2012 | 07:54 AM
98civdx's Avatar
Master Detailer
The crank pulley is not that far away from TDC.
I will make this as clear as possible, YOU CAN'T TAKE THE TIMING COVER OFF WITHOUT REMOVING THE CRANK PULLEY.
Remove the motor mount, there will be a black plug in the cover, remove it, the bolt behind it is the tensoner.
Old Feb 26, 2012 | 01:24 AM
Jabuuty671's Avatar
Default What's wrong with my Timing Belt?
....100th time saying this; did a head gasket change and just put everything back together.
Why's my timing belt like this?
Loose tensioner?
http://youtu.be/5nmOYtcQ-WA
Old Feb 26, 2012 | 03:58 AM
94EG8's Avatar
Seagull Management
related threads merged, again one thread per topic!
As far as the timing belt goes the tensioner appears loose. The belt will always flap and deflect a little, but that's definitely excessive. Put the engine at top dead center, loosen the tensioner adjusting bolt 180°, turn the engine counterclockwise so 3 teeth go by on the cam pulley and tighten the tensioner bolt.
Old Feb 26, 2012 | 05:46 AM
dohc notec's Avatar
Why dont you just stop being lazy and take off the pulley and cover and install the belt correctly. youre gambling with the way you are doing it. if that belt isnt lined up right and you crank it over it will bend valves then youre pulling the head back off. also it has to be rotated twice to check the marks. two crankshaft revolutions for one cam revolution.
Old Feb 26, 2012 | 05:52 AM
The Grumpiest
He stated plainly that he isn't going to do that. Don't know why he's asking for help if he's not going to take the advice.
