Reset ECU timing? Phearable.net ecu
Old Feb 24, 2012 | 02:21 PM
civic89si666's Avatar
Default Reset ECU timing? Phearable.net ecu
Hey guys, I have a b18 in my 95 cx, I just got a phearable chip for my motor. I had a shop solder it in for me. I put the ecu into my car and between like 3k-6k my car has a mis to it. It seems like the knock sensor was throwing a code. I set the mechanical timing good. A friend of mine said to jump the ecu connector and let the car idle for the ecu to set the timing itself. Is this true? Please help. Thanks.
Old Feb 24, 2012 | 02:24 PM
Dc4LsTeG's Avatar
EK9
Default Re: Reset ECU timing? Phearable.net ecu
No that's not true never heard of that..any cels?
Old Feb 24, 2012 | 02:28 PM
grumblemarc's Avatar
The Grumpiest
There is no such thing as ECU timing. Your friend is a moron. You had this chip installed into what ECU? And why did you need it chipped?
Old Feb 24, 2012 | 02:44 PM
I put in a basemap so I can get it tuned on crome. Its a chipped p72 ecu. I figured he was lying but I just thought I'd ask. I know to use a timing light you have to jump it but never heard of having to reset the ecu.
Old Feb 24, 2012 | 03:08 PM
The Grumpiest
I'm confused. You know the basemap is unalterable on that chip right? You can't tune it. If the basemap is causing your issues you're stuck with it until you can get to the tuner. Hope he burns chips.
Old Feb 24, 2012 | 03:50 PM
Ok so the chip is untunable then so be it. Doesn't mean you gotta be an *** about it. So any idea what the actual problem could be?
And I'll swap Ecu tonight and see if anything chamges
Old Feb 24, 2012 | 03:54 PM
SiTR's Avatar
What codes is it throwing
Old Feb 24, 2012 | 04:21 PM
The Grumpiest
Who's being an ***? I'm asking you questions because you don't seem to be aware of some basic information or have made some incorrect/uninformed decisions. If the problem was not there before you got the ECU chipped then it's your basemap.
If the problem was there BEFORE then list the codes you "think" are being thrown.
Old Feb 24, 2012 | 05:28 PM
No codes. I'll swap it and see what happens
Old Feb 26, 2012 | 05:42 AM
dk=gsr's Avatar
will if he is saying to jump the connector by the ecu and do ignition timing, so that the ecu doesn't adjust it by itself, than he is correct. You will need a timing gun and loosen your bolts on your distributor and adjust it too oem (16 btdc)
Mr. Vapor
Honda S2000
Aug 2, 2006 12:09 PM
wilsel
Mar 23, 2005 05:37 PM
EK_vzla
Sep 16, 2004 08:35 AM
ophdehEEzY
Feb 7, 2003 02:11 AM
jonnyR
Sep 25, 2001 04:12 AM
