Which jumper harness should i use
Old Feb 24, 2012 | 12:37 PM
TehTaylor's Avatar
Default Which jumper harness should i use
I have a 96 dx hatch that i just swapped a "poor man's type r" in. it is a jdm b18c block with a pr3 head and pr3 pistons. i am actually using a 99 ex coupe wiring harness in my 96 hatch so and i was wondering should i use a obd2a or obd2b jumper harness (because im not using the 96-98 harness) to obd1 because i want to run a chipped p28 with a b18c5 basemap. I was also wondering if it is safe to run your car on a basemap. any advice would be appreciated thanks
Old Feb 24, 2012 | 12:53 PM
sw388's Avatar
Default Re: Which jumper harness should i use
Its not looking good. check these links out.
http://technet.ff-squad.com/wiring.obd2b.htm
http://technet.ff-squad.com/wiring.obd2a.htm
Old Feb 24, 2012 | 01:09 PM
TehTaylor's Avatar
im guessing i need the obd2b to obd1 jumper harness because im useing the obd2b engine harness
just_dung
11
Jan 7, 2013 11:42 PM
all4show97
Nov 6, 2005 01:44 PM
seerxsi
May 10, 2004 06:07 PM
SikofFalln
Dec 19, 2003 05:14 AM
cmk804
May 9, 2002 03:16 PM
