99 Y7 motor with a MT Y8 intake manifold question.
Old Feb 23, 2012 | 03:52 PM
Marvin1985's Avatar
Default 99 Y7 motor with a MT Y8 intake manifold question.
I have a 99 DX 5spd civic hatch. P2E ecu. My plans are to do a Y8 head swap on the engine. I either will get a 99-00 Ex engine harness or wire in the vtec etc myself.
I have a 99 Y8 5spd intake manifold with TB and IACV coming in the mail as i type this. CAN I RUN THIS ON THE Y7 MOTOR WITH THE P2E ECU FOR NOW? OR must i wait to get another ecu or the head swapped in 1st?
Is there a solution to wire up the 2 wire iacv to be ran with the p2e ecu?
Old Feb 23, 2012 | 03:55 PM
Marvin1985's Avatar
Default Re: 99 Y7 motor with a MT Y8 intake manifold question.
for those of you wondering I AM NOT GONNA DROP THIS SETUP AND SWAP IT. Im in the steps of boosting the motor. its MY project so keep OPINIONS to your own.
Old Feb 23, 2012 | 03:58 PM
grumblemarc's Avatar
The Grumpiest
YOu should learn to search.
Originally Posted by 94EG8
If it's a manual Y8 you'll be throwing IACV codes and have a fluctuating idle, if it's an automatic it will throw a mainshaft position sensor code eventually.
https://www.google.com/search?q=P2E+...ient=firefox-a
Old Feb 23, 2012 | 04:04 PM
Marvin1985's Avatar
ive rattled my brain reading stuff on this. also to many broken links
Old Feb 23, 2012 | 04:08 PM
The Grumpiest
The answer to your question is "Yes". Even though it's wrong.
Old Feb 23, 2012 | 04:10 PM
Marvin1985's Avatar
Originally Posted by grumblemarc
compared to this other thread im running the Y7 engine and p2e ecu NOT the Y8 engine with a p2e
Old Feb 23, 2012 | 04:12 PM
The Grumpiest
There were pages of other search results too.
If the head matches the ECU then what's the problem? None then.
Here's search results for your IACV question.
Old Feb 23, 2012 | 04:24 PM
Marvin1985's Avatar
problem is if i wire the harness to the 2 wire iacv will it work fine on the p2e ecu since its setup for the 3 wire iacv?
edit: think i found answer. i just need to move 1 pin on the ecu from b6 to b23 and then just unpin and disregard b15
CORRECT??????
Old Feb 23, 2012 | 05:47 PM
HondaPartsHero's Avatar
Technical Hero
No it won't run fine. The P2E looks for a 3 wire and the P2P (5 speed ECU) looks for a two wire.
Old Feb 23, 2012 | 05:50 PM
The Grumpiest
I don't think the word "fine" was mentioned. I don't know why people think ECUs are one size fits all.
Old Feb 23, 2012 | 05:51 PM
Texas4door's Avatar
Well, whatever you do, DO NOT get a whole new engine harness; not worth the cost or the headache (or you'll end up like me and have a plug or two missing and then arguing with the seller over the phone about the harness not being complete, etc etc)
Just add the wires and snag a P2P ECU and you should be golden
Old Feb 23, 2012 | 07:15 PM
Marvin1985's Avatar
im gonna just try and find a p2p ecu asap
Crosseman
Jan 14, 2015 05:29 PM
pnwjdm
Sep 23, 2013 07:34 AM
uindaway
Nov 12, 2012 01:25 AM
actek988
May 1, 2012 12:50 PM
phasewest
Dec 12, 2004 08:57 PM
