99 Y7 motor with a MT Y8 intake manifold question.
I have a 99 DX 5spd civic hatch. P2E ecu. My plans are to do a Y8 head swap on the engine. I either will get a 99-00 Ex engine harness or wire in the vtec etc myself.
I have a 99 Y8 5spd intake manifold with TB and IACV coming in the mail as i type this. CAN I RUN THIS ON THE Y7 MOTOR WITH THE P2E ECU FOR NOW? OR must i wait to get another ecu or the head swapped in 1st?
Is there a solution to wire up the 2 wire iacv to be ran with the p2e ecu?
The Grumpiest
Re: 99 Y7 motor with a MT Y8 intake manifold question.
problem is if i wire the harness to the 2 wire iacv will it work fine on the p2e ecu since its setup for the 3 wire iacv?
edit: think i found answer. i just need to move 1 pin on the ecu from b6 to b23 and then just unpin and disregard b15
CORRECT??????
CORRECT??????
Well, whatever you do, DO NOT get a whole new engine harness; not worth the cost or the headache (or you'll end up like me and have a plug or two missing and then arguing with the seller over the phone about the harness not being complete, etc etc)
Just add the wires and snag a P2P ECU and you should be golden
Crosseman
01-14-2015 05:29 PM
uindaway
11-12-2012 01:25 AM
phasewest
12-12-2004 08:57 PM
