weird eletrical problem
Old Feb 23, 2012 | 08:25 AM
9987654321mike's Avatar
Default weird eletrical problem
so i had a d15b in my 90 ef si, and i put a b16a(2 gen) and i converted my single cam harness to obd1. i had problems but i fixed most of them now i can drive it but my brand new altinator wont charge my brand new battery. so i checked for a short by getting my multimeter and puting it on 20volts and puting one of the cable on my ground cable that i disconected and the other cable on the ground terminal while the positive cable was on the positive terminal, and it reads anywhere fron 14.78-18.79 volts. so i started pulling fuses and i found the wen i pull the igition fuse it goes from 18.79 to 16 volts. fuse 12,8,4 (http://img37.imagevenue.com/img.php?..._122_861lo.JPG) i pulled all of these fuses and pulled the ignition fuse out of my fuse box under the hood and it will go to 0.00 volts. idk wat it could be i have a cel code for tps,o2, speedo doesnt work but the milage part works, wont pop vtec, runing p28 with obd0-obd1 jumper. o and i have a rev limit at 1500 wen the gas is parshally pressed.i think it has todo with my tps.other then that it will go all the way to 8k
Old Feb 24, 2012 | 07:20 AM
Default Re: weird eletrical problem
Bump for answer
Old Feb 24, 2012 | 07:36 AM
jlicrx's Avatar
do you have the alternator wire from the engine harness connected at the main underhood fuse box?
wont pop vtec
VTEC will not work if you have codes showing at the ECU
Old Feb 24, 2012 | 08:35 AM
Yea my wire is in the right place
Old Feb 24, 2012 | 10:54 AM
ok so i got vtec to work all i did was changed my p28(chipped but still for singlecam) and i put on my gsr ecu with s200 that i was going to save for wen i go turbo(it came off of my friends turbo b16 hatch). all the check engine lights i get is for iacv now
Old Feb 24, 2012 | 02:03 PM
crvtectim's Avatar
So you were trying to run a dohc motor on a sohc tune? o_O
Old Feb 24, 2012 | 02:45 PM
yea it ran great besides not poping vtec
logeywartooth
Feb 4, 2009 06:23 PM
fivelugsteelies
Audio / Security / Video
Sep 5, 2006 03:41 AM
demon666999
Dec 22, 2004 04:04 PM
jbiggsSE
Sep 6, 2004 11:03 AM
ineedboostbad
Sep 30, 2002 10:41 AM
