ignition cable not working
Old Sep 4, 2006 | 05:24 PM
fivelugsteelies's Avatar
Default ignition cable not working
My car was broken into and my old cd player was stolen. Since then he ignition cable to the head unit has not worked on my 97 civic dx The battery cable is still functioning however. I have checked it while the car is running with a meter and it is reading 0. Is there anouther fuse somewhere that may be causing this? Has anyone else had this problem?
Old Sep 4, 2006 | 08:01 PM
fcm's Avatar
fcm
Old Fart
Default Re: ignition cable not working (fivelugsteelies)
There are 2 fuses for the HU the constant power, fuse 47 - 7.5A, [hot at all times] in the under hood fuse box, [white/blue wire in the OEM radio plug] and fuse 28 - 10A, [hot in acc. or on] in the under dash fuse box, [yellow/red wire in OEM radio plug.
There will also be at least one main acc. fuse in the under hood fuse box, is it only the HU that does not work, [does everything else in the car work]? 94
Old Sep 5, 2006 | 03:41 AM
Default Re: ignition cable not working (fcm)
everything else works, I'm going to check the underdash fuse. Thanks
Rik Emmett
Feb 14, 2010 10:50 PM
pinkspider
Audio / Security / Video
Oct 23, 2006 02:11 PM
winnerpl
Sep 2, 2006 07:03 AM
madcrossover
Jul 27, 2005 07:41 PM
reeder321
11
Feb 28, 2004 06:59 PM
