B20 install parts list for 92-95 Civic?
Old Feb 21, 2012 | 08:53 PM
HatchSi's Avatar
Default B20 install parts list for 92-95 Civic?
Ive searched and searched, and every link turns out to be a dud. Need a list of parts to make the swap happen. any articles/write-ups. Thanks!
Old Feb 21, 2012 | 09:49 PM
EsotericImage's Avatar
Retired Moderator
Default Re: B20 install parts list for 92-95 Civic?
theres hundreds if not thousands of swap threads out there.
i just did a google search and found the 1st page with all the info youll need
Old Feb 22, 2012 | 02:45 PM
HatchSi's Avatar
yes im aware of that, if only one had a complete list or a write up that someone could vouch for and not people saying "correct me if im wrong but I THINK you need this.." would be perfect.
Old Feb 22, 2012 | 02:49 PM
Civic2Fast's Avatar
well just to install the block/tranny (since the head doesn't matter) use a b-series driver mount... rear mount would stay, and tranny mount would stay... b series linkage for whatever tranny you're using...t bracket off the tranny... I just did my b20 vtec turbo install this weekend... PM me if you want
Old Feb 22, 2012 | 02:56 PM
98cdmej6's Avatar
Motor
- Hydraulic Tranny (Y80, S80,S4C)
- ECU (P75)
- Axles
- Shift Linkage
- Stock Motor Mounts *
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Comes With All Sensors Needed
copy and pasted form HMO, the list is for a b18b1 so a few things will be different, i dont know what mounts or shift linkage you will need (some swaps require specific mounts and linkages), or the ecu, or what trans.
Old Feb 22, 2012 | 03:19 PM
HatchSi's Avatar
Originally Posted by 98cdmej6
Motor
- ECU (P75)
- Axles
- Shift Linkage
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
i think your lost.
HatchSi's Avatar
thank you, will do.
Old Feb 22, 2012 | 03:24 PM
Civic2Fast's Avatar
Like I said, I just did a swap this weekend so everything is still pretty fresh... just PM me if you need anything
Old Feb 22, 2012 | 03:53 PM
Deetz's Avatar
Crazy Honda Guy
Considering the B20 is pretty much identical to an LS engine, the swap would be the same also.....yes, i have done one also
Old Feb 22, 2012 | 04:03 PM
LS-turboner's Avatar
Originally Posted by HatchSi
i think your lost.
his list looked solid to me, and yeah, LS and b20 swaps are pretty much identical. so...
Old Feb 22, 2012 | 04:23 PM
HatchSi's Avatar
are you kidding me? Do I really need axels and injectors for it to swap over?!
Old Feb 22, 2012 | 06:32 PM
i assume you are currently d series, and if so, yes, you would need b series axles... and yes, you would need b series injectors...
Old Feb 22, 2012 | 07:49 PM
HatchSi's Avatar
i was being sarcastic, and no. you cant use the CRV axels and please, tell me the difference in B series and D series injectors??? exactly, my D series injectors are 240cc just like all the B series are and they WOULD fit if I had planed on staying stock with this build.
THIS IS WHAT I MEAN PEOPLE, people that have no clue on what they are talking about. Giving false information when not needed.
Old Feb 22, 2012 | 10:15 PM
i didnt say CRV axles, i said B series. no **** you wouldnt use CRV axles...
as far as injectors, you got me there. i i honestly didnt know both b and d were 240's. i would have assumed that the b injectors would be at least a little bigger.
stop being a douche, people are trying to help you. are you forgetting you are on HT? not every post is guaranteed accurate, i never stated that. you obviously arent an expert either, so hop off your high horse. if you know it all, then why are you asking? like said before, its likely been posted 1000 times already. google that ****. anyways, you figure after 8 years on HT youd figure out a b series swap by now.
Old Feb 23, 2012 | 03:07 AM
HatchSi's Avatar
Look...when someone (me) ask for a parts list for a swap, I dont need to know whats coming with A motor when you buy it from HondaMotorsOnline, and you vouching for him say the list looks legit. but im going to stop clogging up my thread, thank you.
Old Feb 28, 2012 | 03:42 PM
EJ1 wilcox's Avatar
Being an *** to people who are trying to help you is not the best way to get your questions answered.
General life skill bro.
EF_monster
Jul 14, 2010 12:09 PM
9.3.S.I.L.U.D.E.
Aug 19, 2009 10:39 AM
danny_ha
Aug 28, 2006 07:59 PM
Solkid138
Apr 10, 2003 08:03 PM
seeNATgo
12
Mar 1, 2003 05:56 PM
