Aftermarket stereo/no keyless entry?
Old Feb 21, 2012 | 05:18 AM
redm3turbo's Avatar
Default Aftermarket stereo/no keyless entry?
Can Someone here please explain this to me, from what I do know, the 96-00 model year civic had their keyless entry/dome light in the stock radio, so removing that will in effect kill your keyless entry-
Now thru internet searching I have come across a few who say that this only applies to 96-98, and that 99-00 are not affected, others say all years are affected.
Now The trick is to, remove the stock stereo, lay it up behind the dash, then splice off the power wire to wire up the new stereo? and then hook up the speakers etc. right?
am I missing anything? I really really want a stereo with a usb stick compatibility, I drive a good 3-400 miles a week and the ease of having a usb stick / sd card to take with me would be a life saver. A little more push wouldnt hurt either. I also DO NOT want to give up keyless entry, unfortunately.
Thanks
Old Feb 21, 2012 | 05:31 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Aftermarket stereo/no keyless entry?
There is an adapter you need to purchase that will allow you to install the new deck and retain the old deck which will have to be shoved behind the dash. I even have a spare one sitting on the floor right now. As far as I know it only applties to 96-98.
Old Feb 21, 2012 | 05:38 AM
EsotericImage's Avatar
Retired Moderator
Old Feb 21, 2012 | 05:42 AM
Axatax's Avatar
There's a version of this harness that is long enough to allow relocation to the underside of the trunk w/2 "L" brackets.
Not having done this, behind the dash (where - ?) may be perfectly acceptable. Food for thought.
Old Feb 21, 2012 | 05:47 AM
redm3turbo's Avatar
so, if I have a 99 civic, I am in the clear, and there's no need to worry, I should just yank her out of there?
or the adapter only works with 96-98?
Old Feb 21, 2012 | 05:52 AM
redm3turbo's Avatar
I keep finding different reports....some SI owners are saying they put in a aftermarket radio and the keyless didnt work, others are saying, they are working no problem.
I dunno if its hit or miss, or if its uncorrectly installing, etc.
Old Feb 21, 2012 | 05:55 AM
Axatax's Avatar
If this is an unmolested vehicle, the keyless entry module for the 99-00 Si is in the driver's kick.
Old Feb 21, 2012 | 06:33 AM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
I had a 2000 4 door and my keyless worked after I swapped out headunits.
Old Feb 21, 2012 | 06:36 AM
kyden's Avatar
96-98 only, as the wiring inside the car changed in 99.
Old Feb 21, 2012 | 07:19 AM
sde780's Avatar
^ correct.
Also, what I did was leave the stock headunit alone, install the aftermarket one where the lower pocket (or OEM CD player) is.
I used the harness that allows you to run both, no issues in my 1997 Civic EX with keyless
Old Feb 21, 2012 | 10:52 AM
redm3turbo's Avatar
The keyless system of 96-98 Civics is integrated into the stock radio. For 99-00 Civics, the keyless unit is located behind the driver's kick panel.
__________________
^ found this, and it is what everyone is saying, so thats amazing news.
So, I just purchased it....Ill throw it in this weekend. Im so excited---usb and sd in front panel, as well as xm.... I couldn't be happier.
oovvutt
Oct 9, 2008 06:36 PM
turbo-2nr
11
Feb 1, 2008 04:57 PM
giddyup21
May 10, 2004 10:20 PM
TheTruth
Audio / Security / Video
Jul 30, 2003 08:10 PM
civic-cpe
Mar 6, 2003 06:50 PM
