h22a4 swap into integra
Old Feb 20, 2012 | 06:21 PM
curt207's Avatar
Default h22a4 swap into integra
ok i recently started a swap hince title. but im lost on bits n pieces of it. im getting a p14 ecu with jumper since the prelude is 97 with obd2 wiring harness.
i know i need to rewire the distrubitor, crankshaft sensor, and injectors. also know i need custom mounts. but idk how to rewire everything right n the guy thats helping me aint around enough to get it done in the time i need it. can anybody give me a dummys way to do all this and let me know of any other problems i might run into
Old Feb 20, 2012 | 06:56 PM
mygoldeneg's Avatar
Default Re: h22a4 swap into integra
p14 ecu is for a h23nonvtec motor
Old Feb 20, 2012 | 07:35 PM
curt207's Avatar
yea but i plan on mapping it to my motor
Old Feb 22, 2012 | 07:01 AM
curt207's Avatar
ok ive got the ecu in and going buti still have the rewiring to do. does any1 know if some1 makes a conversion carness for all the rewiring im going to need to do instead??
Old Feb 22, 2012 | 07:47 AM
grumblemarc's Avatar
The Grumpiest
Amazing. Did you not think of any of this beforehand?
Check the FAQ in the Hybrid section.
Old Feb 22, 2012 | 06:51 PM
curt207's Avatar
well i was kinda in a hurry n made the stupid mistake of buying the full 97 prelude out the scrapyard that way i have the entire swap right there n if i needed anything it was there. but the bolts in my dd integra motor mount broke off inside the motor n it cost to much to get them drilled out n i dont want to drill it cause its to high risk that i f* up the motor by drilling to deep or missing n cracking the block. so its been kinda fix each problem as it comes along then look for new one that might happen.
Old Feb 23, 2012 | 03:44 AM
The Grumpiest
What does the wiring have to do with broken bolts? Check the FAQ in the Hybrid section.
Click this link!!! -----------> Hybrid What works? What isn't practical?
Old Feb 23, 2012 | 05:40 AM
curt207's Avatar
broken bolts was the start of my problems leading up to the wiring issue. n thanks for the tread, but not many are any help
Old Feb 23, 2012 | 12:06 PM
curt207's Avatar
ive come up with a good question. the motor and wiring harnes ive got are both obd2 but im using a jumper harness from the computer to the wiring harness. with both the motor and wiring harness being obd2 shouldnt the jumper harness repin the ecu to where i dont have to rewire the distrubitor and crankshaft sensor?
Old Mar 20, 2012 | 01:17 PM
curt207's Avatar
ok ive got the motor in. radiators proving a tight fit. but my main concern is wiring up the rest of the car. should i rewire the entire thing or just cut n splice. i know rywire does a conversion for something like this but i havent been able to find it. any help?
Old May 2, 2016 | 08:19 PM
Farva83's Avatar
Did anyone have a recommend engine mount brand for h22a4 swap into 94 Integra? I've read up on a few it seems they put the engine in different spots between the brands.
Runamok81
Honda Civic (2001 - 2005)
10
May 13, 2020 03:21 PM
Kungfoohippo
Jun 15, 2016 01:42 PM
persain488
Mar 9, 2011 09:43 AM
TD or Not TD
Nov 23, 2005 07:47 PM
civichbsmn
Jun 7, 2003 04:17 PM
