Someone please help me with D15b
Old Feb 19, 2012 | 07:55 PM
preetyboi06's Avatar
Icon2 Someone please help me with D15b
Whats good everyone.
I am in need of some serious help when it comes to my D15b. Where to begin. First I have a 1994 Honda Civic Hatchback VX that had a D15z1 inside that I swapped out for a D15b. At first I thought I was a regualr D15b but after reading the D15b Vtec FAQ I found out I have/had a
D15b Stage 3 Vtec motor. Now the reason I said had is because when my friend first saw the dual vtec solenoids he said it wasnt needed and I put my old D15z1 solenoid on there. But after reading the D15b Vtec FAQ i have come to find out that I need to dual soienoid inorder for my motor to work correctly. Also I took off the Intake Manifold that the came on the original D15b Stage 3 vtec motor and swapped on a regular y8 maniold. And also the motor didnt come with a dizzy and the shop that help with the swap had a shell laying around and I but the internals from a D16z6 in that shell and now thats on the D15b Stage 3 motor.
Now this is where I need some help. I want to get this motor running right because I am tried of not being able to rev past 5000rpms or no vtec. Now I think from reading the FAQ that this motor is OBD2 correct me if I am wrong. I have a OBD 1 wire harness on there do I need to swap it for a OBD2 or can I use the OBD 1 harness? I know I need the dual vtec solenoids but how do i wire those up? Will my chipped P28 be able to run the motor correctly? Is there a certain dizzy that I need? Can I use the y8 manifold that I have on there or do I need to but back on the stock manifold? ANY HELP WILL BE APPERICATED. I will also post pics up if yall need them.
And one last note. When I try to rev past 5000rpm it sound like metal rubbing together any ideas? And is there anyway to verify other than the dual solenoids that is a Stage 3 Vtec motor?
Thanks for all your help.
Old Feb 20, 2012 | 04:49 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Someone please help me with D15b
Get the proper ECU. You should reinstall the 3 stage stuff and source a P2J ECU.
And stop listening to stupid friends. "It wasn't needed." Like it was leftover and they stuck it on there from the factory. Jeez.
Old Feb 20, 2012 | 04:53 AM
EsotericImage's Avatar
Retired Moderator
If it isnt broke, Dont fix it
Old Feb 20, 2012 | 05:21 AM
NVturbo's Avatar
O.G. triple O.G.
D15B motors swapped into VX chassis....that's a typical problem, even with the correct P06 ECU. It has something to do with the wiring at the ECU.
Old Feb 20, 2012 | 10:44 AM
Question couldn't I just get a USDM D16z6 or Y8 head and put that on the block that I have? That would eliminate the hassle of having to go through everything to get the 2 stage vtec working.
ever'sneighborhood
Aug 23, 2013 03:01 AM
95 vtec
26
Mar 31, 2008 06:52 AM
si 2
Oct 20, 2006 07:55 PM
vtecspeed1320
11
Jan 22, 2006 07:55 PM
