No power to fuel pump.
Ill start by saying i have a 92 civic with a d16z6 swap. The car run for about two months after the swap and the starter went out. Replaced it and now im noticing that the fuel pump isn't priming. I have replaced the pump and the main relay. It has p28 ecu and the cel stays on. Im stumped.
You sir don't know what you are talking about. Did you read the thread? A disconnected G101 ground will cause the CEL to remain on steady (not blink) both with and without the service connector jumped. This is referred to as CEL code 0. Familiarize yourself with the CEL sticky at the top.
Okay so I checked the g101 it looks good, I tried pulling the cel codes and it wasn't giving me any. While checking for them the fuel pump came on the cel went off and it stayed at a steady idle for a min or so and then shut off. The cel came back on and now im back were I started.
Unplug ECU connector A and then turn the key to ON(II). If you ground the A7 or A8 terminal (Grn/Yel wire), does the fuel pump run? Try this test multiple times to see whether the pump always runs.
http://www.phearable.net/tech/wiring...schematics.gif
rupensane
14
May 16, 2009 12:28 AM
h23vtec_dc2
Oct 24, 2007 06:13 PM
