Crx Fuel Pump Won't Prime
I just replaced the main relay and still nothing. I put a test light to the black and yellow fuel pump power wire and turned the key, its not getting power. What could this be? It worked fine two days ago
Re: Crx Fuel Pump Won't Prime
check the ground wire with a ring connector on the end that comes out of the engine harness and connects to a bolt on the thermostat housing - make sure it is clean and secure
i used a rywire harness with my k-swap, ryan told me without k-pro my fuel pump will not run, i had to ground out my fuel pump wire at my ecu and run a switch on main rely untill i can get k-pro i no its kinda half a$$ but it works for now, call hybrid racing and ask what they think, this is a common problem with k-swap cars and i'm sure hybrid racing guys will point you in the right way
i ran my fuel pump wire from my rywire harness to ground and hooked a switch to my main relay, my ecu wont turn my fuel pump on without k-pro, hope this helps call hybrid and see what they say about it sure they can help
I used this to manually wire my relay. #5 goes to a thick 12v wire that switches on when the key is to the on/start positions. #1 was getting constant power so I left it alone. Left #2 #3 and #4 alone. Grounded #8 and let #7 power the pump. Now my pump comes on when the key is in the on position, and A13/A15 are getting 12v power, but engine wont start. Could it be flooded? Why would it have started before, but wont start now? I checked the ecu fuse and its good
