Suspension & Brakes Theory, alignment, spring rates....
Adjustable coilover problem...
Old Feb 19, 2012 | 04:22 PM
Acura Del Sol's Avatar
Default Adjustable coilover problem...
Ok so on the adjustable coilovers I have on the front of my 97 sol have a Alan wrench bolt you have loosen to raise/lower the ride. Well the one my driver side coilover was stripped. So I drilled the bolt out to where I could adjust it. So I raised it up and obviously couldn't tighten that bolt and wrapped the threads in gorilla tape to prevent it from threading back down.
So my question is, is it safe to not have that hex bolt ??
I drove some on it and all is well so far..
Old Feb 19, 2012 | 04:24 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Adjustable coilover problem...
Here's my two questions. Why do you think it's there in the first place? Do YOU think it's safe?
Old Feb 19, 2012 | 04:47 PM
I'm hoping just to tighten enough to where it won't thread. But idk if maybe I can open up wide enough to just slide down the threads without turning
Old Feb 19, 2012 | 05:48 PM
Kohen's Avatar
go to the hardware store and get a new one?
Old Feb 19, 2012 | 05:50 PM
The Grumpiest
Seriously.
Old Feb 19, 2012 | 06:39 PM
98civdx's Avatar
Master Detailer
^That, if you didn't fudge up the threads. If you did, try and re thread it.
OR, you could always try to hunt down another perch, and use it to luck the other one in.
I only run one in front, and I don't think it's ever moved, But I haven't checked them, basing this on how the car looks.
Old Feb 19, 2012 | 07:06 PM
Yup threads are busted . Im just going to hope it lasts until I buy a new setup
Old Feb 19, 2012 | 08:51 PM
Kohen's Avatar
what brand coilovers do you have right now?
Old Feb 20, 2012 | 09:29 PM
Idk ground control I think
Old Feb 21, 2012 | 11:26 PM
Thanks that's what I needed to hear
Old Feb 22, 2012 | 04:27 AM
Libertariat's Avatar
Ek Forever y0!
Probably wouldn't be too hard to re-tap the messed up threads. But again, a new sleeve wouldn't be expensive direct from eibach either.
Old Feb 22, 2012 | 05:18 AM
tron_'s Avatar
10 Year Member
Drill
Tap
Bolt
Beer
Old Feb 22, 2012 | 10:56 AM
Haha tron has the idea.
But yeah I called gc and they told me I have to send them an email with pictures of my coilover for then to sell me a new perch. But I mean these are a year or two old so theyre dirty and can't see the grou d control name any longer. So hopefully they can make a refund
harlen
Suspension & Brakes
Apr 26, 2006 11:53 PM
Beau Gotti
Suspension & Brakes
Oct 19, 2005 04:24 PM
sbrocks1
Mar 14, 2002 04:24 PM
92Si
Jul 25, 2001 10:37 AM
