f22a1 Sohc Build what bearings should i use
Old Feb 19, 2012 | 06:47 AM
greymamba23's Avatar
Default f22a1 Sohc Build what bearings should i use
I have a f22a1 Im building. I already have wiseco pistons h22 rods, balance shaft delete kit, h23 intake mani/tb. Im at a stand still right now bc I need main and rod bearings and I would like feedback on the best ones to use.
Old Feb 19, 2012 | 01:48 PM
zelseman's Avatar
Default Re: f22a1 Sohc Build what bearings should i use
Why are you building an f22 instead of an H-series?
Old Feb 19, 2012 | 05:55 PM
BergRacing21's Avatar
why not?
Old Feb 19, 2012 | 05:57 PM
On my build i just used OEM honda bearings...did a lot of searches and stuff and a lot of big names still do cause they can do that job. But King makes aftermarket OEM and oversized and another company i can't think off the top of my head.
Old Feb 19, 2012 | 06:03 PM
hondasdohc's Avatar
use acl or king they are good no problems with them so far. I'm using king main bearings and thrust washer and rod bearings on a f22a1 g22 vtec build i did a month ago. It has f20b pistons on f22a1 rods and crank and an f20b head with 11.78:1 compression.
bigbpatel
11
Jan 8, 2013 02:53 PM
My JDM EJ8
Nov 18, 2009 08:55 PM
Boostage
Oct 5, 2009 07:21 PM
88Snatch
Dec 23, 2008 07:22 PM
Modifiedinteg
Nov 13, 2003 06:42 PM
