what is this plug?
srry if i posted in the wrong section
i recently got a 92 ex from this kid that had glow gauges, neon lights etc on the inside..
so after a day removing all that crap i saw this plug under the dash by the pedals
its just hanging there, it goes into the harness but i cant seem to find the female end of it..
2 wires
solid green/white line
solid green/wred strip
and what is this plug with a jumper.. the jumper was there from the kid
2 wires
Top pic looks like the brake light switch (T-tap connectors are typically for aftermarket cruise control)
Second pic looks like the plug for the clutch start switch relay.
Have you actually looked at the brake switch on top of the pedal to see of the plug is plugged into it? Also the clutch relay has nothing to do with clutch engagement.
brake switch is plugd up.. im bout to go look at this guys car to get few parts and see if i can trace to where is goes
ok after goin to this guys house to get few parts off his eg, i look at the gray plug it dont go to nothig its just taped to the harness
now as far as the green plug with the jumper wire.. i found where it gose.. its kinda small and tight ..(lol) to get to so i plug it up and as i turnd the key over i jus get light and hear the fuel pump, but key wont turn over untill i unplug and put the jumper back on.
it plugs into a black 4 prong fuse looking thing...
yea i know its a relay but to wat?.. my eg is manual..
and like i stated when i plug it up and keyd the key i got no turn over.. i just heard fuel pump prime and lights come on... and then when i unplugd it and put the jumper back in and started up just fine with no problem.
Like I said earlier, clutch start switch relay. Did you have the clutch shoved in when you tried to start the car? The relay might actually be bad as well, which would totally explain someone bypassing it.
You might be able to get what at a parts store, not sure. You can definitely get it from honda, or used at a junkyard. I *think* the sunroof relays are the same.
Ok cool thanks.. yea i stil have no power to the windows, sun roof door locks.. ill try the parts store today when i get off wrk..
Ooh yea off the subject. Is there a ground wire behind the ashtray that is boltd to the lower part of the dash metal part?..
baca00ex
Sep 7, 2013 12:31 PM
jdmboy91
Mar 26, 2011 12:57 AM
blinger
Apr 25, 2007 02:00 PM
93civicexthug
Mar 23, 2007 02:20 PM
