2L built ls vtec what turbo?
Old Feb 17, 2012 | 05:59 PM
SloHa+ch's Avatar
Default 2L built ls vtec what turbo?
hey guys im trying to figure out what turbo to run im shooting for high 400 to low 500whp on pump 94....dont want alot of lag what turbo would be good for me...car is street driven from time to time but will be at track every weekend.
Price range 600-800 i know tight budget but any input guys?
build list
Edelbrock Intake Manifold Victor X
bottom end was built by laskey racing
Benson sleeved block b18a 84mm
balanced and micropolished crank
CP pistons and rings with upgraded wrist pins (9:5:1)
Eagle H beam rods rods
ACL Bearings
OEM (TypeR) oil pump
OEM Water Pump
OEM timing belt
Lower gasket set
APR main stud kit
Blueprint and assembly
Block is O-ringed with golden eagle wire
Golden eagle Vtec Conversion Head Dowels
Golden eagle 84MM head gasket
Golden Eagle head studs
Golden Eagle MAIN GIRDLE kit
-Precision CNC machined from 6061T6 billet aluminum.
-With OEM main bolts & washers
-Includes oil pickup and windage tray
-P72 oil panHead is a PR3 head
port matched
supertech valvetrain
springs/ti retainers
Stainless Steel, Nitride coated valves
CTR cams
BDL adjustable cam gears
valve cover tapped for catch can
Old Feb 17, 2012 | 06:50 PM
TheShodan's Avatar
Moderator
Default Re: 2L built ls vtec what turbo?
With this criteria you've posted, only anything 60-62lbs/min will work for that level, and with that budget, you can go used GT35R, or new GT3540S, SC61XX, 62xx, or GTK750.
You don't have a choice but to deal with LAG. you want that kind of power using that kind of fuel, you're going to get laggy..deal with it.
Old Feb 17, 2012 | 07:37 PM
SloHa+ch's Avatar
what do u guys think about sc61...full boost by 5000rpm? that wouldnt be the end of the world.
Old Feb 17, 2012 | 07:41 PM
SloHa+ch's Avatar
or is there gonna be more of a lag?
Old Feb 17, 2012 | 07:45 PM
Whiterice-gsr's Avatar
u could make 500 with a gt3076r but out of your price range, why not save a few more bucks and buy the right turbo for what u want. if u compromise you'll regret it. full boost at 5000 rpm doesnt give u alot of room on a ls block i wouldnt be happy with that.
Old Feb 17, 2012 | 07:46 PM
TheShodan's Avatar
Moderator
you didn't list what was done with the cylinder head. That makes slight differences. Otherwise, yes, you're about right.
Old Feb 17, 2012 | 07:47 PM
TheShodan's Avatar
Moderator
True, but that's also almost maxxed out doing that. He'd be over 25-30psi all day to do that. There's one or two alternatives, but they are out of his price range of $600-$800. So he's stuck with Precision or used Garrett or used Turbonetics.
Old Feb 17, 2012 | 10:16 PM
SloHa+ch's Avatar
i think im gonna go with sc61 due to its cheap lag doesnt seem 2 bad. i got a garrett 57 trim from b18b setup but .48ar lol wouldnt take long to run out of breath. yeah gt3076r out of price range. thanks for input guys.
Old Feb 17, 2012 | 11:33 PM
SloHa+ch's Avatar
ive been looking cant seem to find sc6152e anywhere new.... anyone know ive been search for about 2 hours and found nothing but used ones... if you guys know a good place please let me know.I have also found threads of sc6262s w .82 hitting full boost at 5500-6000rpm and holding it till 9200....any input what would spool better?
Old Feb 18, 2012 | 06:00 AM
u need smaller man, wheres your rev limiter and whats your head. if your rev limiter is 7200 hitting full boost at 6000rpm is absolutely useless. a 57 trim could get u to about 425 but u will have full boost at 35-3800 rpm. if u are able to rev to 9000 then u can have a bigger turbo. it all depends.
Old Feb 18, 2012 | 06:25 AM
shanebadoo's Avatar
Slohatch, what you're asking isn't computing for me. You have a good build list and you want to cheap out on the turbo. I'm really not understanding it. But since you asked, have a look at the STC Reaper turbo. Look in loco joe's thread for fantastic results and good response.
Old Feb 18, 2012 | 06:32 AM
^^^ the reaper is awesome, im going with the silver surfer a little smaller but good for up to 600hp and full spool by 4200.
Old Feb 18, 2012 | 10:11 AM
SloHa+ch's Avatar
pr3 head head its built...ill be reving it to 8500-9.
Old Feb 18, 2012 | 12:14 PM
SloHa+ch's Avatar
lol u guys know the real names to these turbos? i found loco thread but just says garrett reaper not the real name unless that is it then i cant find it forsale anywehre...lol
Old Feb 18, 2012 | 12:46 PM
gabocastano's Avatar
Talk to the Shodan, he sells them and are the best you can get but you need to pay more.
Old Feb 18, 2012 | 12:53 PM
yes these are custom t3/t4 turbos with garrett parts. the silver surfer is 58lbs min flow and good to 600hp if u search stc reaper u will get more results. the surfer is comparable to a gt30 turbo but cheaper and makes better top end power. it is still over your buget though which is why i say save a few more bucks up and buy something like the surfer/reaper
Old Feb 18, 2012 | 03:55 PM
SloHa+ch's Avatar
i decided to go with 6262 with .82ar thanks for input guys
SloHa+ch
Mar 23, 2012 02:06 PM
VtecAllTheWay
Feb 28, 2012 05:50 PM
illassek9
Nov 2, 2011 08:31 PM
illassek9
mysterysktr7
Oct 8, 2009 02:13 PM
