Hwo to get an EJ8 Bar'd, already running a b16a2
Hi guys, I'm running a b16a2 motor swap, I'm currently running a p28 ecu - base map has been changed to a p30, I was wondering what more would I have to do to make BAR LEGAL? Please help it would be the best!
As I understand it you will fail instantly for the jumper harness. You should call up a station locally and talk to someone.
they will check to see if your engine is the same year as your car or newer.. so if u have a motor that is a 98' or less, u FAIL
and it better be USDM not! JDM or u FAIL
Mad-Mike
Jul 7, 2011 06:54 AM
