Hwo to get an EJ8 Bar'd, already running a b16a2
Hi guys, I'm running a b16a2 motor swap, I'm currently running a p28 ecu - base map has been changed to a p30, I was wondering what more would I have to do to make BAR LEGAL? Please help it would be the best!
The Grumpiest
Re: Hwo to get an EJ8 Bar'd, already running a b16a2
As I understand it you will fail instantly for the jumper harness. You should call up a station locally and talk to someone.
ecu has to match the engine or it will fail..
i bard a gsr and everything had to match..
also engine has to be the same yr or newer of your car
basically just get a p2t an just wire harness everything correctly and i'll be fine?
they will check to see if your engine is the same year as your car or newer.. so if u have a motor that is a 98' or less, u FAIL
and it better be USDM not! JDM or u FAIL
Mad-Mike
07-07-2011 06:54 AM
