Zex nitrous question
Old Oct 9, 2002 | 06:03 PM
Soled Out's Avatar
Default Zex nitrous question
I just got my zex kit all installed and i went to make a run, but the bottle was only at 600 on the pressure gauge, and i read it should be up around 900, its a full bottle, and no apparent leaks, only problem i can see is that my bottles cold ( 40 degrees outside) would this make that much of a difference?
Old Oct 9, 2002 | 06:27 PM
speeddave's Avatar
Default Re: Zex nitrous question (D Series Pwr!!!)
it should be ok, its kinda low. might be worth it to invest in a bottle warmer, or put it inside where its warm and then put it in the car. it won't operate as well as it would with the right psi.
Old Oct 9, 2002 | 06:39 PM
00civicvtec's Avatar
Get a bottle warmer, optimal pressure is between 900-950
Old Oct 9, 2002 | 06:49 PM
civichxb16's Avatar
bottle warmer
Old Oct 9, 2002 | 06:52 PM
pelotudo's Avatar
You are correct sir
Doesn't effect pressure. If it's cold, the pressure will drop.
Correct, and yes. Get a warmer. Stick it on there. Keep it about 900-950, and you will feel a significant difference. You'll also feel a difference between a full bottle and a 1/2 full bottle. It's weird, but you can feel it.
jB
[Modified by PelowisheshewascoolTudo, 10:53 PM 10/9/2002]
Old Oct 9, 2002 | 07:12 PM
d-wreck's Avatar
Default Re: Zex nitrous question (PelowisheshewascoolTudo)
yeah man if the climate you live in is typically that cold buy a heater, eventually it will pay for itself since the kit would be working so much better.
oh and by the way zex is fun
derek
Old Oct 10, 2002 | 12:22 PM
Soled Out's Avatar
Default Re: Zex nitrous question (d-wreck)
i have a bottle warmer, but i got it used an am trying to figure out how to wire it up since it dont have any directions
Old Oct 11, 2002 | 06:17 AM
MikeMAN's Avatar
try zex's website, i know they had some pdf's of the instructions a while back..not sure if they still have em'
good luck!
mike
kornerk12
Apr 8, 2009 05:06 PM
d15.hatch
Apr 4, 2006 03:29 PM
Layziebtnh055
Aug 8, 2005 12:47 PM
ZexyAccord
Mar 8, 2005 01:27 PM
tegasaurus
Jan 11, 2003 02:31 AM
