B series short shifter question
Old Feb 16, 2012 | 08:08 PM
Acura Del Sol's Avatar
Icon2 B series short shifter question
I have a 97 sol swapped to b18b with gsr tranny and was wondering how putting a short shifter in would work or even possible?
Old Feb 16, 2012 | 08:24 PM
Cap'N Chronic's Avatar
Default Re: B series short shifter question
Should be able to swap one in. I'd check out the revvo short shifters on ebay. No point spending 60+ dollars on a name brand one.. Its pretty easy to do:
-Pull out the trim pieces covering your shifter.
-Go under your car, unbolt the old shifter from the linkage.
-Unbolt the stabilizer bar from the car itself, should be two bolts, and two holding the stabilizer bushing. (4 altogether)
-Unbolt stabilizer bar from transmission.
-(I find it's easiest to drop out the entire stabilizer bar)
-Pop the new shifter in, and installation is the reverse of removal.
Word of advice, I'd look into some poly shifter bushings on ebay, they're cheap and they're a decent mod since you'll already be under there.
Old Feb 16, 2012 | 10:25 PM
Yeah but will the integra shirt shifter fit right in the del sols
Old Feb 17, 2012 | 03:48 AM
NVturbo's Avatar
O.G. triple O.G.
NO, not without modification. The bottom part is the same size but is different in width. On a serious note, short shifters are a waste of time and money. If you want a better shifting feel, get Energy Suspension bushings for the stock shifter.
Old Feb 17, 2012 | 04:00 AM
DelSol-B18's Avatar
Don't get eBay. A buddy had one and it snapped. Go on summitracing.com an get a b&m one like $45 plus shipping
Old Feb 17, 2012 | 06:07 AM
It's really all about preference. Personally I like the short throw shifters better than stock. And your buddy must have been slamming some serious gears to snap a shifter..
Old Feb 17, 2012 | 06:31 AM
DelSol-B18's Avatar
Yep. Anything eBay isn't the best on quality but short throw is the way to go!
Old Feb 17, 2012 | 06:56 AM
Blasney's Avatar
From: On the road...generally in the central United States...
I like the GSR shifter as far as a low-cost, fairly easy upgrade goes. It depends on your personal preference and budget, though. You want cheap and effective, go the GSR route. You want to spend a bit more for a bit shorter throw, go aftermarket.
Old Feb 17, 2012 | 07:56 AM
Red_Army's Avatar
B&M SS. 45-150
energy suspension bushings. 15.
worth it.
Old Feb 17, 2012 | 09:51 AM
97dssi's Avatar
I got a skunk2 dual bend short shifter and energy suspension bushings in my 97 Del sol with b16. It’s no problem. I love it. Don’t get cheap shifter from eBay, it will break because it’s not good quality.
Old Feb 17, 2012 | 09:53 AM
delsolo95's Avatar
haha c'mon guys, ebay isnt a brand! its the buyer that buys cheap quality items from the seller on ebay lol
Old Feb 17, 2012 | 10:27 AM
ek4_b16a's Avatar
Any no name shifter off eBay or anywhere else you can get them from will be no good. Had one in my car and it snapped where the threads ended for the ****. B&M is great! I have one and love it. Find what you like and swap it in. Pretty sure the GSR shifter will work for your delsol. GL
Old Feb 18, 2012 | 10:57 AM
decon's Avatar
Hey guys got a question on the short throw shifters. Im getting an 99 si with an ls/vtec swap with tranny. Um any advice on a a short throw that will work with that setup? I dont have any year info on the tranny yet cuz my brother is working getting it right now as im currently out of the country working.
Old Feb 18, 2012 | 12:39 PM
ek4_b16a's Avatar
find some friends with different short shifters and try them out. It is to your liking. I like my single bend B&M shifter because it sits low. It's to your preference. GL
Old Feb 19, 2012 | 01:48 AM
decon's Avatar
thanks ill check out the b&m and see it its to my liking
Old Feb 19, 2012 | 03:39 AM
DelSol-B18's Avatar
Doesn't matter what setup you have. Get a short throw that fits that car. Simple as that.
techlove92
Transmission & Drivetrain
15
Jan 3, 2013 08:53 PM
highrpm666
Dec 29, 2010 05:28 PM
saikouEF8
44
Mar 21, 2006 02:54 PM
D C 5
Feb 15, 2006 08:32 PM
AVXHATCH
Feb 27, 2003 02:26 PM
