B16 Throttle issue.
Old Feb 15, 2012 | 01:55 PM
CrazyFNG's Avatar
Default B16 Throttle issue.
I have a stock b16 with stock injectors and walbro 255 fuel pump. The engine Idles fine and there are no CEL's running stock p28 that worked fine on another car. What happens is if ease the throttle open it runs fine. But if I press the throttle too fast or if I crack the throttle just a litte it bogs and shuts off and I can see a little white cloud of smoke in the intake manifold.
Any help would be great
Old Feb 15, 2012 | 04:31 PM
CrazyFNG's Avatar
Default Re: B16 Throttle issue.
Update: I cleaned throttle body and now only thing it is doing once you rev the motor when returns back down to idle it wants to stall.
Old Feb 15, 2012 | 06:07 PM
turbohatch96y7's Avatar
Is there an idle adjustment anywhere on the throttle body? Is it loosing air or fuel?
Old Feb 15, 2012 | 07:08 PM
10psiLsEf2's Avatar
had this issue on my gsr. turned out to bemy iacv.
Old Feb 15, 2012 | 07:10 PM
CrazyFNG's Avatar
not sure if it is loosing any,there is an idle adjustment. the idle right now is between 700-900
Old Feb 15, 2012 | 07:11 PM
CrazyFNG's Avatar
I will check and clean it and see what happens
Old Feb 15, 2012 | 09:54 PM
CrazyFNG's Avatar
Cleaned IACV did nothing
switched out IACV that did nothing
I moved the throttle stop up and it got rid of the bogging issue.
Old Feb 16, 2012 | 02:13 PM
So its running good now?? No more bogging?
Old Feb 16, 2012 | 02:32 PM
mrsinger's Avatar
maybe the throttle positioning sensor?
i had this problem, but it was a d series engine..i had it narrowed down to the tps and the iacv
CrazyFNG
Feb 15, 2012 04:30 PM
magicguy
Jan 30, 2009 02:00 PM
longfellahh
Oct 16, 2008 02:35 PM
BB1 H22A LUDE
Feb 25, 2008 01:55 PM
