Yet another fuel pump prob
Old Feb 15, 2012 | 12:13 PM
lapbattleEG's Avatar
Default Yet another fuel pump prob
Hey everyone.. iv been wondering these forums for awhile now as a guest but finally decided to become a member and ask you guys some ?'s.... i have the what seems to be typical no prime fuel pump... i cleaned/ checked the Therm stat housing ground everything seems fine there.. My main relay is brand new...battery fully charged.. but fuel pump will not turn on... it does turn on when i jump the 2 terminals at the main relay connector though not with the relay plugged in.... so my ? to everyone here is what do you think would be the next step to look at?.. possibly the ecu? or go back to the ground wire?... any help/ suggestions will be highly appreciated.... The vehicle is a 92 civic hatch with d15z1 bone stock
Old Feb 15, 2012 | 01:57 PM
98EJ7Y8's Avatar
Default Re: Yet another fuel pump prob
i have the same issue .. my main relay is brand new but pump doesnt prime when key is turned .. so id tell you to check ur ecu .. my pump also turns on when jumped with a 12v power source but will not prime with key .. i have a post in here that ive been looking for answers for like a week ,.,, good luck trying to figure this problem out
98EJ7Y8's Avatar
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/98-civic-fuel-pressure-3024984/
Old Feb 15, 2012 | 07:03 PM
Thanks man ill keep an eye on ur post if no one lends a hand here
Old Feb 16, 2012 | 09:51 AM
BUMP
Old Feb 16, 2012 | 04:36 PM
problem fixed mods please delete!
Old Feb 16, 2012 | 04:38 PM
98EJ7Y8's Avatar
what was the issue
Old Feb 16, 2012 | 04:41 PM
grumblemarc's Avatar
The Grumpiest
Damn. At least PM this man the solution!
Old Feb 17, 2012 | 10:48 AM
i ended up just rewiring the ground wire to the main relay since so many people have seen to have problems with it....
slowEGles
May 13, 2013 06:16 PM
Hypermax
17
Aug 13, 2011 04:44 AM
JDMB20TDA
Aug 18, 2007 08:45 AM
insomniac791
Jan 22, 2004 04:23 PM
RCSIVTEC
May 12, 2002 10:14 PM
