Custom E-Brake Cable/Pulley Setup
Old Feb 15, 2012 | 08:56 AM
adrian1281's Avatar
Default Custom E-Brake Cable/Pulley Setup
I'm building a Factory Five Cobra and I need to fab something up for the e-brake.
I purchased a Lokar E-Brake handle, but most if not all using it complain there isn't enough leverage/pull on the cables. I've decided to go with a cable/pulley setup.
There are two versions of this, here are some pics. Which should I go with which will give me maximum leverage? I'm leaning more towards "Ver. A" since it takes up the less space.
Also, I should make the pulley that the cable makes a 180 around smaller or larger in order to get the most leverage?
Ver. A
Ver. B
Old Feb 15, 2012 | 09:03 AM
codenamezero's Avatar
Default Re: Custom E-Brake Cable/Pulley Setup
Version A gives you a bit more leverage no?
Old Feb 15, 2012 | 07:37 PM
laydoutjimmy's Avatar
I personally don't see how either gives more or less "pull" then the other. You need to change the distance between the e brake handle pivot point and the point in which the steel braided cable mounts. The farther these two points are from one another, the more the cable will be pulled. Hope this helps
Old Feb 15, 2012 | 08:54 PM
SovXietday's Avatar
You are more or less going to get the same "leverage" from both. When you wrap the cable around the pulley like that you make it take half the effort to pull the cable, but you need to pull twice as far.
Different pulleys won't really make any kind of noticable difference. Put together what you feel is going to be the most reliable and try to give as much "throw" as possible on the ebrake itself.
Old Feb 17, 2012 | 10:40 PM
ihaterust's Avatar
change the pivot point on the e brake handle.
Old Feb 18, 2012 | 03:41 PM
black0hatch's Avatar
^ ya that will give you more leverage.
Old Feb 19, 2012 | 04:37 PM
adrian1281's Avatar
Thanks for all the replies, but the pivot point can't be changed. At least not without redoing the whole handle since it is already chromed and welded together. Here's what it looks like:
How it is supposed to connect to the e-brake cables directly:
Old Feb 27, 2012 | 09:04 PM
uberEFtuner's Avatar
With version A. The smaller pulley could be omitted. Just attach the cable directly to rear brake cables. Two pulleys is not needed.
Unless you want it to be easier to pull.
Old Feb 28, 2012 | 05:12 AM
tepid1's Avatar
They are needed in ver a because he needs to keep it under the trans tunnel aluminum plating.
Old Feb 28, 2012 | 05:51 AM
It will be twice as hard to pull this way. But it should maintain the same cable path. Just omit the small pulley and don't attach it to the frame.
Old Feb 28, 2012 | 07:24 AM
SovXietday's Avatar
^ I think that's the problem they're having, without the pulley system like he has it routed guys are having a really hard time activating the ebrake. It's too heavy.
At least, that's what I gathered from the initial post.
Old Feb 28, 2012 | 06:55 PM
adrian1281's Avatar
I don't think the problem is that it's too hard to engage the e-brake.
The main problem is that the Lokar handle we use does not have enough travel, so guys are coming up with ways to create more leverage.
Instead of using a pulley/cable configuration, some have done this:
Old Feb 28, 2012 | 07:01 PM
adrian1281's Avatar
There is also this configuration, but it seems to be opposite of what I posted above with the red bracket. The red bracket seems to be "correct" in that the handle is at the fulcrum of the bracket. If it is directly in the middle, it will provide twice as much mechanical advantage, correct?
Old Mar 1, 2012 | 05:03 PM
welfarepc's Avatar
if you are running out of travel, a pulley wont help you, it will hurt you
imho, extend the "business end" of the ebrake handle and paint it. heh
Old Mar 4, 2012 | 07:44 AM
whoiszdizguy's Avatar
bumpppppp for creatativity
Mccormick009
Aug 22, 2014 01:16 PM
AtoZ
Feb 5, 2009 10:39 AM
msmithgsr2131
Oct 16, 2007 02:41 PM
JoshuaVTEC
Aug 12, 2007 08:55 PM
xxxmikenicexxx
May 24, 2006 12:33 PM
