aem ems 1060 coil driver
Old Feb 15, 2012 | 03:26 AM
turbo timm's Avatar
Default aem ems 1060 coil driver
hi, i am running a seperate ignition amplifier and a wasted spark system on my car. the two coil drivers seem too have gave up. can i move to the spare two coil driver pins? if so what needs too be done? is it common for the drivers to go, is there a fix for it? thanks in advance
Old Feb 15, 2012 | 07:39 AM
Rtype16's Avatar
Default Re: aem ems 1060 coil driver
Look at the instruction manual that came with the EMS. It will list the spare coil drivers for the vehicle. The most likely went out because you are over driving the circuit. Too much dwell for your setup. Once you find the spare drivers re-wire the outputs to those and change the settings in the software.
Old Feb 21, 2012 | 05:15 AM
turbo timm's Avatar
its been running this setup for a while now without issue. i tried the extra drivers with no joy. just too give a bit more info, it runs a crank trigger with no cam reference with the sync off. now and again when you reload the map and with the plugs out it will spark weakly. no spark with plugs in. the rpm signal reads 250-300. beginning to think the ecu has a few gremlins inside.
Old Feb 21, 2012 | 08:36 AM
Rtype16's Avatar
give the tech department a call at310-484-2322
Natural Aspirations
Engine Management and Tuning
Oct 9, 2012 05:57 PM
B16A1-EF9
Dec 29, 2009 05:12 AM
FTP racing
Dec 12, 2007 09:20 AM
cptengineer
Mar 6, 2006 06:47 AM
Mr.Saturn
Apr 6, 2003 06:10 PM
